Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
On the piece that covers the brushbar and motor (the clear plastic piece that has the dyson logo), it looks like a small plastic ridge that holds the cap for the brushbar snapped off. Would too much wobbling of the brushbar cause it to turn on and off? The switch seems fine.
  • thecaldwells Oct 14, 2010
    Thanks much for the help. I saw the reset buttom mentioned other places, but I cannot see it on my DC15. Does anyone have a picture of what I am looking for or great detail on where it is and how to reach it? I admit that this is all really far out of my element. Thanks in advance for any help.
  • Anonymous Mar 29, 2014
    end cap not holding the brushbar in properley
    President:
  • 1,140 Answers
In theory, yes. If the brushbar isn't held firmly, then the belt isn't running smoothly which puts more strain on the motor. This can cause the motor to get hot very quickly which will trip the thermal overload protection.
After it switches off, do you have to wait several minutes before it will turn back on?
Posted on Oct 13, 2010
  • 3 more comments
  • thecaldwells Oct 13, 2010
    Thanks for the input. The motor sort of flickers on and off as we move the vacuum across the carpet. However, it did seem like it completely shut off for my wife this afternoon. The brushbar stopped moving despite the vacuum maintaining its suction.
  • DILLIGAF
    DILLIGAF Oct 13, 2010
    Sorry for not replying sooner. I somehow got infected with a rather aggessive Trojan shortly after posting! Just spent 2 hours doing System restore and offline virus scans.
    The DC15 has 2 motors. One for suction and one to rotate the brushes. There should be a small red reset switch behind the brushes. Try pushing this down and see if it fixes the problem.
    Your description actually sounds like a faulty switch or a loose connection either at the switch or the motor. The switch workings are fairly sensitive and the additional vibration from the wobbling brushbar may be causing the contacts to open and close, powering the motor off and on repeatedly.
    However, if the brushbar is wobbling around, it's going to cause all sorts of problems. The belt wont be running true and will cause more friction. This will wear the belt out quickly and it will break or slip - either way it will cause the brushbar to stop turning. It could also put more load on the motor and burn the motor out but the thermal fuse should stop this by cutting power to the motor when it gets too hot.
    Basically, you should replace the broken part that is causing the brushbar to wobble to avoid further damage. This might cure the electrical fault as well.
  • DILLIGAF
    DILLIGAF Oct 14, 2010
    This is what your looking for:
    http://www.diytools.co.uk/diy/Main/sp-64...
    I couldn't find a pic with this attached to the hoover. It should be behind the brushes but if not, it will definitely be on the cleaning head (where the brushes are housed) somewhere.
  • DILLIGAF
    Thanks for the info! I will keep looking for it this morning.
Does anyone have "duct" assembly instructions for Dyson DC 24? (Not the owners assembly manual)
Google Dyson. co On the drop down window, find your model, type in Dyson DC 24, at bottom of page click on shopping info, click parts. you can order from there.
Oct 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Got a broken piece from dc25 wand locking mech plus a small clear plastic clip,how does it go back together
Hi there, it's Jack at Dyson.
In order for us to confirm exactly which piece has broken and how to resolve this issue, we would need to take some further details when you have your DC25 easily to hand.
At your earliest convenience, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or replacement part is needed, we should also be able to confirm if this would be covered under the Dyson warranty.
We'll look forward to speaking with you.
Sep 26, 2014 | Dyson Vacuums
Loud whining when the dyson goes on and off
Dyson vacuum cleaner - Strange noise troubleshooting.
WHISTLING NOISE
If you are getting strange noises from your Dyson vacuum cleaner, listen very carefully as each one is telling you something different. Look through the list and see if you can spot your strange noise.
If you are getting a whistling noise, that usually indicates an air leak (vacuum leak) of some kind.
If you also have a loss of suction, make sure you check for blockages, torn seals, or parts not fitted correctly such as u-bends etc.
A seal may also be missing so go through our poor suction troubleshooting and see if you can spot where the suction dies.
If you try all of that with no luck and have a machine that has a HEPA filter like the DC07 or DC14 especially, then remove the HEPA filter and check the circular seal underneath the HEPA filter. If this has moved even slightly this may be causing the whistling, try removing the seal and putting the filter back in.
The DC24 and DC25 ball models are known for this, you turn the machine off and it gives off a strange revving/flapping noise. To diagnose this properly then remove the HEPA filter (the one in the ball) turn it back on and off again. If the noise has gone then replace the HEPA filter with a new one. Go to our parts store to order one
POPPING NOISE
A popping noise accompanied by a really pungent burning smell 99% of the time indicates a motor failure with your Dyson vacuum cleaner.
This will involve a motor and usually a post motor filter replacement as it usually burns the post filter or at best traps that lovely smell in the filter for eternity.
Sometimes a popping noise is a bit simpler.
All Dyson vacuum cleaners are fitted with something called a bleed valve, if the Dyson becomes blocked the bleed valve opens allowing air to get to the motor so it doesn't get too hot and fail.
The bleed valve on most models makes a popping noise, clear the blockage and/or wash your filter and that should solve it.
Go to our suction problems page to troubleshoot it.
RATCHET NOISE
If you hear the dreaded ratcheting noise it'll scare your kids and pets and make you switch it off immediately. It sounds like a football rattle but worse.
The ratcheting noise only happens on Dyson vacuum cleaners with a clutch.
Don't know the difference?
Look at the two models below, the one to the left does not have a clutch the one to the right does.
Still don't see it? Look at the bottom left of each machine, the purple ones have a purple dial meaning it has a clutch (could be any colour dial) the yellow one doesn't.
Anyway, back to the ratchet noise. This usually only happens when something is obstructing the brushbar, it stops the brushbar to prevent the belt from breaking (clutch belts cannot be replaced by the customer) and makes the ratchet noise to warn you.
Removing the obstruction, like a sock or paperclip from the brushbar will usually get it working again.
If you remove the obstruction and it still ratchets, then unplug your Dyson and try turning the brushbar by hand. It should be quite loose, if not remove the brushbar by grabbing it and twisting and pulling until it comes out.
When you get it out try turning it if it is still tight then remove the end caps and check for dust or hair build up in the ends and also remove any hair built up around the brushbar. Spray some WD40 in the ends if necessary, put the end caps back on the brushbar and try again. If it is still tight to turn then I recommend a new brushbar.
If the brushbar is spinning freely by hand then the odds are it will require a new clutch. We sell these in our parts store one clutch fits most models, the only exception is any DC03 and the DC04 Zorbster model. We sell all clutches and brushbars in our parts store
POPPING NOISE
RATCHET NOISE
NO CLUTCH
CLUTCH
LOUD VIBRATING, SCREECHING OR REVVING NOISE
If your Dyson vacuum cleaner is making a loud vibrating or revving noise.
First thing to try is empty your bin and make sure there are no blockages, if that doesn't solve it then remove the brushbar and then try switching your Dyson back on again.
If the noise is normal again then it is your brushbar or possibly clutch if applicable. Remove the brushbar, cut off any hair, remove the end caps of the brushbar and apply grease, WD-40 etc to the bearings. Put the end caps back on again and try and spin it, does it spin freely? If not then the brush may need replacing.
If the noise remains with the brushbar removed then I'm afraid it is a motor failure and will need a motor replacement.
If your motor fails with this noise usually it is down to the filters not being washed often enough and dust choking the motor.
If you have one of the ball model Dysons, such as DC15, DC24, DC25 etc. this could be your brushbar motor, brush bar or the end cap!
Best thing to do is remove your brushbar and end cap and inspect them. Any obvious sign of wear or damage then replace them. Also inspect the part at the other end of were the brushbar sits (this is the brushbar motor and drives the brushbar) Is it worn or damaged? If so you will need a new brushbar motor.
Try switching it on with the brushbar removed and the brushbar motor turned off at the switch.
Is the noise still there? If yes then there is a good chance you need a new main motor (not brush bar motor)
If your answer was no, try switching it on with the brush bar motor on (will need to be in the leaned back position for this) Is the noise still there? Yes, then you will need a new brushbar motor.
If your answer was no again, then replace your brushbar and end cap.
One more thing to try with the DC24 and DC25 ball models is to remove the HEPA filter (the one in the ball) switch it back on and off again. Has the noise gone? Yes, then the HEPA filter needs to be replaced.
http://www.repairmydyson.com/#!strange-noise/c3ha
Mar 01, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
The brushbar on my model 17 didn't work. I found the micro switch next to the main motor wasn't making. There is a plastic piece that presses the lever of the micro switch to energize the brushbar...
I'm sorry to hear you're having difficulties with your DC17. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 05, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brushbar stops when the vacuum is pulled back -- works some, doesn't some. DC 15 4 yrs old,on 6th brushbar.
This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver (No: 15) to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers on the right side of the vacuum. There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
See full details with photos at: http://www.bajwa.net/?q=node/3
Jul 09, 2011 | Dyson DC15 All Floors - The Ball Bagless...
My brushbar isn't rotating but the belt and motor are fine - any suggestions please
The brushbar needs to rotate in the end pieces that hold it onto the head. If the motor and belts are fine, your problem is the brushbar is seized on its shaft. To solve, remove the bottom plate. Then lift out the end of the brushbar opposite the belt, but do not remove the brushbar. Grab the bar with one hand and the end cap with the other and pull the end cap off. It just slides on the shaft. If the shaft comes with the cap, no problem. That means the opposite end cap came off the shaft. Clean the dust/lint out of there and then take a look at the other end for the same. Slide everything back together and the bar should now be free to rotate on the shaft. Reinstall the bottom plate and you are ready to go.
Jan 27, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Burning plastic smell when using the vacuum cleaner
HI, Thanks for contacting the FixYa team.
1. Plastic Burning Smell - This means that there is friction in a plastic part of your Dyson. The only place this will be coming from is the BrushBar. The brushbar has jammed somehow. The smell arises as the rubber belt is still trying to turn the plastic brushbar but the brushbar is not moving. To solve the problem you will need to unscrew the soleplate using a 2 pence piece, this is done by inserting the 2 pence piece into the 3 plastic screws on the underneath of the Dyson. Turn the screws a quarter anticlockwise. You can then remove the soleplate. You will probably see that there is a build up of debris by the brushbar. This is more common on The Animal version as pet hair mixed with dust gets stuck in here, especially if the machine has been used on a damp or wet surface. So clean this area out and then try manually rotating the brush bar in each direction. If you have been using the machine for too long with the burning smell then it is likely that your brushbar will be melted where the belt attaches to it. If this is the case then you will need to get a new brushbar. If the brushbar is not too damaged check that the belt has not broken. If the belt has not broken then replace the soleplate. Turn the screws a quarter in a clockwise direction. Should your belt be broken then please re-post and we will show you how to sort this. Thank you
Oct 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction quit working. Someone awhile back said
You have to refit the internal hose. This is the small clear hose at the bottom of the machine. Pull it off where it sits next to the wheel first - make sure that the gray piece of rubber is still on the hose - next, twist the hose off where it connects to the brushbar - inspect the hose and make sure you don't have any holes in it - put it back on by twisting it onto the side of the brushbar first - then line the gray piece of plastic end up with the hole next to the wheel and push and twist it back over the whole. Give it a small tug to ensue that it is on properly. Test the vacuum. If that didn't solve it you have a blockage somewhere down the line and you may have to wash the filter if you haven't done so in the past 3-6 months.
Jun 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Roller motor on a DC17 dyson wont turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
Feb 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
347 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
