My daughter was working on her laptop last night and she said it wasnt working right so she shut it off and when she turned it back on the screen was black - I tried the f2 key last night trying to get it to run in safe mode, etc but it would not work. Pls advise
    Genius:
  • 1,035 Answers
Hi!
Try to keep tapping on F8 get the Advance Boot Menu where you can try going to safemode.. And from there you can run system restore..
Hope this helps.. :D
Posted on Oct 13, 2010
    Novelist:
    Champion:
  • 227 Answers
CPU more than likely went bad because of overheat. Its not worth fixing unless you KNOW you can do it yourself Laptops are a nightmare to work on
Just a suggestion but laptops are for people who MUST carry their PCs around. The do not have a long lifespan. Desktops are much more durable
I have a gateway notebook model #mt6451 i turned it off last night and i turned it back on this morning and the screen wasnt coming on the power button lite up cd made noise fan working and hard drive...
First thing to try:
Remove your battery and charger, hold the power button for 10-15 seconds. Plug the laptop into mains ONLY leaving the battery out. Try powering it up.
If the laptop powers up ok, simply shut-down and re-insert your battery. You should find your laptop will continue to work fine for the foreseeable future, this kind of issue is a common occurrence on laptops.
If not I would then try re-seating your RAM/Memory, if that doesn't work and you have more than one stick remove one at a time to see if either one is causing the problem. If you have only one stick find a replacement to test your laptop with.
If you are still finding the same issues with the laptop I would then proceed to reseat all components of laptop, including the CPU.
If the issues continue I would then remove all non-essential components one by one, each time attempting to power the laptop. At worst you will eventually end up with just the mainboard, CPU, RAM and an external monitor plugged into the mainboard, that still doesn't function correctly. I would then conclude your mainboard needs replacing.
Mar 19, 2014 | Computers & Internet
Last night I had a pen in the laying on the fold of my laptop. I forgot and pinched it for a second. Then I continued to shut it down. this moring I have vertical lines on the right side of my...
You will need to get your LCD screen replaced in order to have it working correctly, the damaged screen can not be repaired. I suggest getting an estimate before you decide to have it fixed. The only other option is to hook up a external monitor to the video output located on the back of your laptop.
Dec 22, 2010 | Computers & Internet
HOW TO TURN THE NIGHT LIGHT ON ON AN IBM THINKPAD T30.
To turn the "Thinklight" on and off hold down Fn and hit the PgUp key.
Regards.
Nov 23, 2009 | IBM ThinkPad T30 2366 Notebook
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Laptop computer won't turn on...
this is ur battery problem so just get ur baterry cheked
Jun 25, 2009 | HP Compaq Evo n610c Notebook
Mp3 won't charge or turn on and computer won't recognize it
the mp3 player might be going bad, might have to get a new one
Apr 22, 2009 | Philips GoGear HDD075/17 MP3 Player
Acer laptop stuck on Acer welcome screen.
Remove the hard drive and try it again, if no change also remove the DVD rom drive.
The computer is trying to access the drives, but failing and will just sit there and keep trying until it either succeeds or eventually fails & then will report it.
The fact it has hung like this would indicate the hard drive controller board has failed though and is no longer reporting back to the bios when it is queried.
If this gets you past that point, then before you take a hammer to the drive, reseat it back into the slot firmly and try it again.
Apr 29, 2008 | Acer Aspire 5610-4648 Notebook
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
