Question about Shure SM58 Professional Microphone
I have a shure sm58 wireless with a bad off/on switch- it is stuck in "on", fortunately. I can't get the case open to slide the guts out. I have removed the ring clip, but it doesn't drop out. What should I do?
  • 1 more comment
  • Terry Dearmore Oct 14, 2010
    Where should I apply the pressure? I am applying pressure to the battery contacts but it won't budge. I tried pushing in the battery test button and it is out of the way, but how do I get past the switch itself?
    I am wanting to replace the on/off switch on a Shure SM58 wireless microphone. I have been able to get the ring clip removed, but am hesitant to apply too much pressure to the battery contacts to get the guts to fall out. How does this thing come apart to expose the on/off switch for removal?
  • Terry Dearmore Oct 17, 2010
    I am taking the advice and having the work done by the factory. Thanks for the help!
  • 3,083 Answers
This web blog explains the disassembly process of the sm58. Go a few paragraphs down and you'll get to the explanation:
http://www.chittproductions.com/2008/05/how-to-fix-broken-dynamic-microphone.html
You have to do some desoldering of wires to get the guts out, so take your time, and take notes or pictures as you go. This sounds like a tricky process, so take your time and be careful not to cause more damage. Most people don't seem to recommend taking one apart unless you really have to.
Good luck, and hope this gets you fixed up.
Posted on Oct 14, 2010
    Genius:
  • 1,478 Answers
You will need to exact little more pressure and be consistent with it, perhaps, i will advice you replace the on/off switch for effective use.
Take care.
Posted on Oct 13, 2010
HOW TO REMOVE CIRCUIT BOARD FROM SHURE PGX2/SM58
First, unscrew the cartridge from the top. The round circuit board on top of the transmitter has a cutout on the switch side. Slide a screwdriver through that cutout and pop out the bezel the surrounds the switch. Remove the spring clip that is around the round circuit board and slide out the circuit board.
Apr 26, 2014 | Shure PGX-2 Wireless Handheld Microphone...
Is sm58 wireless mic compatible t4a receiver-shure
The "SM58" is just the cartridge on the top. It would depend on the model of handheld transmitter. The model number is on a sticker in the battery compartment.
Nov 07, 2012 | Shure SLX24/58 Wireless Microphone System...
Shure PGX2/SM58 Power Button
Unscrew the cartridge from the top. Slide a screw driver down inside to pop off the switch cover. Remove the large "c" clip to remove the circuit board.
Mar 27, 2012 | Shure PGX-2 Wireless Handheld Microphone...
Shure sm58 Wireless Capsule how to open
The Shure wireless mic that has the switches on the side is tricky to open. The first thing is to take the cover off the switches and do NOT lose the two buttons. To remove the plastic cover very CAREFULLY pry up with a knife point near the center from one side. There is a plastic tab at each end of the little plastic part that is easily broken. by prying at the center of one side these tabs are pulled in a little and will release. There is not much that is serviceable within the wireless part so it is kind of a moot point to open it. When installing the buttons back one has to align each before snapping the cover back on.
Jan 16, 2012 | Shure SM58 Professional Microphone
Can anyone please tell me how to use a shure sm58 radio antenna wireless microphone or manual as ive just purchased this of ebay and no instructions came with it so a little lost as no sound coming from...
Shure SM58 is not a wireless microphone, so clarify me the exact model for your wireless device in order to help you.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 06, 2011 | Shure SM58 Professional Microphone
SM58 wireless with the power button stuck.
Common problem... the mic has been dropped and the guys of it have shifted so that the switch can't move far enough to turn on or off as the case may be. Gently pry out the little plastic piece around the switch and see if it works properly without the piece in place. If it does, then you have to remove the guts from the case or somehow slide them the correct direction so switch can move faar enough. Often a small plastic index has been broken in the fall so verify the guts will stay in the right place for the switch operation before reassembly.
Jul 20, 2011 | Shure SM58 Professional Microphone
On/off switch is flaky. After a period of not being reliable, it now won't turn on. I've opened up the plastic and I can get the inside capsule loose, but it won't slide out... it's blocked by plastic...
Pop off the bezel that surrounds the switch actuator. Once you do that, the switch actuator will fall our in your hands. Remove the C-clip at the top of the microphone and the circuit board can be slid out the top.
The actuator moves the actual switch. So, if you are having problems with the actual switch, then you will need to replace it. Replacement parts can be ordered from Shure Parts at 800-516-2525.
It might cost less and be easier to simply send the microphone to Shure for repairs.
Feb 07, 2011 | Shure PGX 2/SM58 R1 Professional...
Where to buy a the swivel adapter for shure sm58 and shure wireless lx2 sm58
You can buy the swivels from Beyer, they have several sizes.
In my opinion he best you can get.
Regards,
Gerard
Jan 05, 2010 | Shure (LX287CC) Professional Microphone
Trying to open my Shure sm58 beta
About half way up the body you will see a seam. The body with the cartridge and wind screen separates from the bottom half of the body at that juncture. You have to unscrew one from the other. You will see wires that have to be unsoldered. Make note of where they were soldered and do the same thing for both the mike with the dead cartridge and the mike with the good cartridge. Swap straight across and you're done. Hope this helps.
May 30, 2009 | Shure (LX287CC) Professional Microphone
Shure SM58 Professional Microphone Logo
1,114 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
