Question about Jensen VM9410 Car DVD Player
Parking brake on a phase linear uv8
I want to be able to watch my dvds while driving for my passengers but the blue screen comes up saying it ileagle to watch while driving so wat do i do with the pink parking brake wire so i watch my dvds
  • Anonymous Jul 01, 2008
    dvd wont work while riding wat i need to do
  • Anonymous Aug 03, 2008
    Don't Know where the parking brake is
Your radio needs to be on am/fm tuner hit system set up put in 543210 u should here a beep after each number anew menu will pop up hit brake override and watch all day long
Posted on Nov 25, 2008
Place the pink wire to a ground. Hope this works for you.
Posted on Jun 07, 2008
2 Suggested Answers
  • 32 Answers
SOURCE: parking brake on a phase linear uv8
pulll the unit out there will be a wire marked park brake or most likly pink (remeber coming from the head unit ) next splice it in to the black wire or to a ground
Posted on Jun 03, 2009
Linear phase uv8 and letting my kid watch movies while i drive
You can let your kidwatch DVD but not while your driving unless the screen is out of the view of the driver
Feb 17, 2010 | Phase Linear UDV9010 Car DVD Player
How do i override the emergency brake with remote to uv8
Look for dvd hack for that model. I see some on ebay
Jan 05, 2010 | Jensen VM9510 Car DVD Player
Jan 30, 2009 | Jensen VM9411 Car Video Player
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
Jenson Phase Linear UV8 sub input
u need to get a Y splitter to make that one female into 2 females so both the red and blue plug in. its like 5 bucks. one end is a male rca connection then splits to to female rca's
Jan 07, 2009 | Car Audio & Video
Phase linear uv8 parking brake problem
i did not make this lil tutorial as i found it on the ecoustics forum at http://forum.ecoustics.com/bbs/messages/4/278797.html i do not take credit for this tutorial. i found it very helpful.
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit. fullsizechevysig.jpg
May 15, 2008 | Car Audio & Video
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
Dec 03, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9410 Car DVD Player Logo
242 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
