Question about Briggs & Stratton Garden
I have a 550 series briggs and stratton earthquake rototiller . athe problem i,mhaving is i push the primer 3 times like it says it burns off that gas but wont keep running
  • 97 Answers
SOURCE: Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Posted on Mar 19, 2009
  • 41 Answers
SOURCE: my briggs and stratton 550 series lawnmower will not run
Could be float in carb.sticking.Take carb off & apart.Put float in water to see if it floats.Check float by shaking next to ear.If you hear any sound,you need a new float.
Posted on Aug 29, 2009
bbreton
  • 437 Answers
SOURCE: needs new primer
You are searching for part number 181558. It is a snap in primer bulb with a piece of fuel line.
Posted on Oct 02, 2009
bbreton
  • 437 Answers
SOURCE: i need a forwward cable for an earthquake reartine
I googled Earthquake 5020DM tiller and show a site that has a technical manual. It has the diagrams and parts numbers. It looks like the forward and reverse cable are the same. You may have to call ARDISAM direct to get the cable.
  • 18 Answers
SOURCE: briggs and stratton model #917388520 6.5hp bought
If you had it shipped to you, I would change the oil as they usually ship with a junky oil that isn't very good. Take it to sears, see what you need done with it. Hopefully it is warrantied, and if you need briggs and stratton parts for it I wouldn't get em from sears, I always use ereplacementparts.com for any parts I need to repair my stuff. Good luck to ya.
Posted on Mar 23, 2010
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Push ball gets sucked in after 3-4 minutes of running always restarts and runs
I assume you mean the primer bulb is imploding? I would check my gas cap by running it with the cap removed and see if it still happens. Sounds like you may have a plugged vent in the gas cap, causing a vacuum problem in the lines.
Nov 09, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
I have a Poulan 550 158cc Push Mower. Two Model #'s 96132004200 and PR0550N21RH3. Two Serial #'s 0901075421770 and 011309M001762. The mower will run if primed then dies. The carb. is on the tank. I...
does it have fresh gas in it, If so time to rebuild the carb, even though you blew through all holes there is a diaphram inside the carb that pumps gas to it, so I suggest you take the carb apart and clean inside out and replace the diaphram, the way you describe it only runs on primer, tells me the carb is not getting fuel. Good Luck
May 14, 2011 | Poulan Pro PR550N21R 21Inch Briggs ...
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Brand new B&S series 550. 2nd time trying to start, runs for 5 seconds and stops. Pumping the primer will keep it running for 5 seconds at a time. First use, 4 weeks earlier, ran like a dream! What is...
Water will cause problems like this. Ethanol in the fuel causes the water in the air to pool in the tank. 2011 engines will be equipped with a better orfice that will not corrode from the water. You might contact a local dealer like www.arcolawn.com and get the updated tube.
good luck
Nov 13, 2010 | Briggs & Stratton 190cc 875 Series OHV...
The 'primer' doesn't work on my mower's Briggs & Stratton engine. Is there an easy fix?
You can try pumping primer bulb 10-15 times instead of 3 or 4 that manual probably suggests. We have a craftsman 22 inch cut push mower with a 3.5 H.P. BRIGGS &STRATTON engine and if you don't prime it at least a dozen times it will not start. It is possible that you have a small hole in your primer bulb in which case it can't create suction to bring gas to carburator. If this is the problem you can purchase a new bulb and seal at most larger SEARS stores or service centers.I would guess that if you have manual for mower you can get part number and phone number to get new parts .Hope this helps. Thanks
Nov 08, 2010 | Garden
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Garden Logo
156 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
