Question about Life Fitness 95Ti Treadmill 95 Ti
When you press Quickstart it says "Please Wait" and it stays like that for about 2 minutes then you can begin workout? Not sure how to fix.
I have seen this a couple of times. The incline motor probably has a gear problem. Remove hood and find the plug for the incline motor, disconnect and then reset treadmill. treadmill should work but will not incline until incline motor is repaired or replaced. Good luck.
Posted on Feb 08, 2011
How do i change the minutes on the clock of 2005 dosge durango . i can change hour
You might try the following:
Clock Setting Procedure
1. Press and hold the time button until the hours blink.
2. Adjust the hours by turning the right side Tune / Audio control.
3. After the hours are adjusted, press the right side Tune / Audio control to set the minutes. The minutes will begin to blink.
4. Adjust the minutes using the right side Tune / Audio control.
5. To exit, press any button/knob or wait 5 seconds.
I hope that helps!
Mar 23, 2013 | Cars & Trucks
How to change precor932i lenguage
When start-up prompt "PRESS ENTER TO BEGIN OR PRESS QUICK
START" appears, access the Club Program by sequentially pressing
STOP, SPEED , SPEED , SPEED , RESET, SPEED , SPEED , and
SPEED . (Numbers on the display appear in sequence: 4, 5, 6, 5, 1, 5, 6,
and 5.)
Note: You must sequentially press each key within 4 seconds of each other
or the display reverts back to the start-up prompt.
6. Maximum Speed: Use any or key to designate a speed limit between
1 and 15 mph (1 and 24 kph). The speed you designate limits the speed of
the treadmill. Press ENTER when the desired speed appears.
7. Maximum Workout Time: Use any or key to designate a time limit
between 10 and 240 minutes. The amount of time you choose limits the
length of a person's workout. (This does not include the automatic 5-minute
cool-down period.) Press ENTER to accept the time limit.
Note: Continuous pressure on the arrow key lets you scroll through the
numbers being displayed.
8. Language: Use any or key if you want to change the language. You can
choose between English, German, Spanish, or French. When you change
the language, you affect all the prompts and informational messages that
appear on the display. Select the language being displayed by pressing
ENTER.
9. Custom Courses (C964i only): The course profile appears in the center
display. (If you want to customize course number 2, press ENTER.)
When you enter custom mode, you have the ability to "draw over" an existing
God bless you
Feb 22, 2013 | Precor 932i Treadmill
What kinds of workouts can I do on the elliptical machine?
Youcan do endurance workout, hill climbing workout, and interval training. Formore information on these workouts, check out this website: http://www.livestrong.com/article/100587-workout-programs-elliptical-trainer
Aug 05, 2012 | Exercise & Fitness
How long do I need to work out with a medicine ball to see results?
Effective workouts with medicine balls should last between 30-45 minutes, 2-3 times a week. Each session to consist of 8-10 different exercises with 2-3 sets of each. It won't take too long for you to begin noticing results.
I can't find the reset button on my life fitness T7-0.
The pan has to be removed to get to the reset button on mine, I have the same model
Sep 27, 2017 | Life Fitness T70 Treadmill
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
On the Kodak ESP 5200 series what does a 3501 error mean? can it be fixed by a user? will new cartridges fix the problem?
Hi!
The 3501 error code means "acces door open"
Please be sure that the printer's acces door is well closed.
If this doesn't fix the problem, please do the following:
1. Turn the printer off by pressing the on/off button
2. Unplug the power cord
3. wait for 1 minute
4. plug the power cord back in
5. turn the printer on
Hope it helped.
Regards,
Bogdan
Aug 20, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
How can i set my clock timing in my navigation cd player
Audio control.
begin to blink.
control.
Not sure but I think the radio needs to be off when you do this but don't quote me on that. I hope this helps you and good luck.
Mar 30, 2011 | 2006 Jeep Commander
WHEN I TURN MY CAMERA ON THE SCREEN STAYS BLACK & THE LENS WILL OPEN & CLOSE LIKE 4 OR 5 TIMES THEN GO OFF.... I HAVE TRIED TAKING THE MEM CARD & BATTERY OUT BUT THAT DOES NOT SEEM TO WORK...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. turn on camera and see.if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Apr 23, 2010 | Olympus FE-280 Digital Camera
When trying to turn on HP Media Center desktop, I press start button then button starts to blink green and orange and computer will not boot. I unplug CPU and start button stays lit for atleast 30 seconds.
this issue has been taken up on this forum, with a plethora of solutions. This is a power issue. Easiest solution, unplug the computer, wait 5 minutes, plug it back in, wait 2 minutes, then turn it on. That will fix your problem 90% of the time. If not, here is a bunch of solutions:
http://www.fixya.com/support/t350366-power_green_light_flashing_hp_desk_top
Dec 27, 2009 | HP Media Center m7250n (ED842AA) PC...
Life Fitness 95Ti Treadmill 95 Ti Logo
610 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
