Question about Canon IXY 1000 Digital Camera
My memory card is full. How do I unload pictures or do I need a new card??
  • 10,594 Answers
You do not need to have another memory card.
All is needed to transfer picture files in computer then delete stored images in memory card through format memory option in camera menu to take/ store fresh pictures.
Connect camera with computer via usb cord or take out memory card from camera and plug it into memory card reader (that is widely available in stores) and hook it in usb port of computer to transfer pictures.
Let me know if you have additional question.
Thanks.
Posted on Oct 13, 2010
How do you turn the beeping off on a Vivitar Vivicam 8018 camera??
if the internal memory is full the camera will beep,try unloading some of the internal pictures to an external media,like your computer or memory card and it should stop.
hope this helps.
Jan 08, 2011 | Cameras
I have a problem unloading the pictures from the camera to the camera
Not understanding the question "unloading the pictures from the camera to the camera"?
Are you meaning downloading pictures from the camera to the computer?
If so the best and least complicated way is through an optional inexpensive card reader which plugs into a USB port on the computer. Until you purchase this optional device this is the "flow" to use.
Make sure you have ample battery power in the camera, turn off the camera and connect the special cable which will have a "mini" USB connection the camera end and a normal size USB connection on the other end. Connect to the camera and a USB port on the computer. Turn on the camera. Depending on your computer operating system there should be a notice of device found and a external drive icon appears on your desktop. Create a new folder in "My Documents" and give it a name I usually use the date. then open the icon, double click the icon withing that drive and your pictures will appears as thumbnails click on the first one then go up and "select all" copy and then click on the new folder you just created and past. within a few seconds all your pictures will have been transferred from the memory card to your computer hard drive. Now here is the important part go back to the memory card drive and click on the icon possibly a right click and "eject" the memory card. this shuts off the drive and you can then remove the cables from the computer then the camera. Failure to "eject" the memory card can and will corrupt the card and files within that card. in short it will crash the card and the camera it's installed into.
Dec 18, 2010 | Cameras
Says memory card full only 4 pictures on it 2 gig card
Copy the pictures to your PC then reformat the card and move them back this should do the trick
Jun 12, 2010 | SanDisk 2GB microSD Memory Card
Internal Memory full; No memory card in; Will not take pictures;
You need to get a memory card and promise to never use the internal memory again....it only causes problems as you have found out. When you get the new card follow this procedure: 1. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to format the internal memory. 2. Insert the new card and do the format thing again to prepare the new card. Happy photography!
Mar 14, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Cannot download all of pictures onto pc.
First of all, you should forget about using the internal memory...it just causes problems (as you can readily see). Always use a memory card. If any of the pics on your camera are important, you should download them to your computer before continuing. Then, go into the menu and find "reset"...follow the on-screen instructions. Then, with the card out of the camera, go into the menu and find "format"...follow the on-screen instructions. Then insert a blank memory card and go into the menu and find "format" again...follow the on-screen instructions. From this point on, your life will be wonderful.
Feb 02, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
How to empty memory card
Easiest way...go into the menu and find "format"...follow the on-screen instructions.
Dec 28, 2009 | Canon PowerShot A75 Digital Camera
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
extreme7528@yahoo.com
Oct 13, 2009 | Cameras
Removed memory card from camera
Yep, the corrupted files are stored on the memory card.
A new card should sort it out, only you will probably lose your files.
Often you do not even need a new card, you just format the old one.
Nov 12, 2008 | Cameras
Memory card says it's full
This can happen if there is a hidden recycle folder on the card. I had a similar problem that was solved by reformating the card.
Dec 23, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Memory Full
What size is the memory card. What picture size has the camera been set to? Check out your Manual for the images sizes viz a vis memory card capacity - and come back
Jul 13, 2007 | Casio Exilim EX-Z57 Digital Camera
Canon IXY 1000 Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
