Question about Vacuums
We used our Hoover SteamVac F6207-900 for the first time today and it did not suction at all. Please help. It emptied all of the clean water/detergent as I cleaned the carpet, but no dirty water came up into the empty tank. Thanks!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=639624
Generic problem for all Vacuums
Posted by medglen on Jun 01, 2008
Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a clog or a vacuum leak in the vacuum line. The suction should be able to pickup the water into the holding tank for you. So please feel free to contact your local vacuum dealer or you can use a wire coat hanger to try to unclog the vacuum but if that fails contact the factory or your local vac dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
The suction stopped working after emptying dirty water and filling up with new water and cleaner
I have an older Hoover SteamVac Supreme #F5815 and I'm having trouble figuring out how to clean the part in the front that the dirty water goes thru before it gets to the tank. How do I clean it?
Mar 06, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover SteamVac has been doing a wonderful job but in two instances, after emptying the dirty water and reattaching the reservoir, the machine has lost suction. The first time I was able to make it work...
look for the lower tank filter to be clean. also make sure the lower tank lid is on properly. latch when installed on machine. Make sure the front panel duct is on the lower tank.
Oct 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I only used it once or twice and then the suction stopped and I can't figure out what went wrong. Hoover Steam Vac
This model has suction as soon as you turn on the machine. make sure the lower tank lid is on properly and the tank is latched in place. check the hose attachment door if that may be open. There is a float in the tank that will stop suction whenit is time to change the water, make sure the tank is empty.
Aug 06, 2009 | Hoover F7431-900 SteamVac Vacuum
No suction in new Hoover Steam Vacs
http://www.hoover.com/pdfs/manuals/F5914900.pdf hopefully this helps
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Automatic "shut off" not turning off
Check the filter in the tank, if a dual V model you will have a screen, if not a dual V move the foam filter down about 1/4" to help.The lid on either model needs to be securely in place, as well as locking the left and right latches. On the Dual V model, check the hose door on the front.
Feb 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Lost suction
there is a screen by the brush that may be clogged. Make sure the water tank is on tight
Feb 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Lost Suction
Usually when there is no suction, one cause is the lid to the recovery tank is not on all of the way in the back. Also if you have that foam filter on the underneath side of the recovery tank lid, it needs to have a 1/4 in or so gap from the top of the filter to the top of the lid. Some models also have a duct that sits in front of the recovery tank, and if it isn't there, you have no suction.
Apr 20, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
216 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
