Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Help me the nipple end of tv where the cable antenna goes in had popped out what can i do to get back in
  • 51 Answers
If you are decent with soldering iron you can repair it yourself. Remove the back, and remove the signal board from the unit. Unsolder the Tuner from the board( If I've lost you already, call a TV shop for repair) Remove the shields on the tuner and inspect for damage to the tuner itself. If the board is in good shape, replace the RF connector with RCA # 215543. you'l have to unsolder the old ends connector ( the wire thats still there broken ) from the board, then attach the new end, and solder to the board. Then using high heat, solder the Connector to the tuner housing. Replace tuner on board, hook everything back up, and you should be in business.
Posted on Jun 04, 2008
How do i get my Dynex TV to work on an antenna
Easy. First put up a good outside or wall antenna. Then run a coax cable (not flat lead wire) from the antenna to the tv. To do this you need to get a "balum" to go from the antenna to the coax wire. It's a small plastic 'transformer' (( about the size of your pinky finger)). The other end of the coax wire should have an 'F' connector put on it so it can screw into the F connection on the back of the tv set. Then get your remote and go to the input of your tv and change it to antenna input. Then do a channel scan. Let it finish scanning and it will let you know how many channels it picked up. If you're in a big city then you may pick up as many as 100 or more channels. If you're in the country, you may only pick up about 5 channels! If you need more channels then go back to Home Depot or Lowes and get an 'antenna amplifier'. Hopefully one that has about 25db gain. Most only have about 10db gain but the higher the number the better. It should be put inline between the tv and the antenna so you'll need another coax cable for the amplifier to the tv. The wire that comes from the antenna goes directly to the 'input' of the amplifier. Then from the 'output' of it to the tv. You'll love it once it's done and it's cheaper than cable or any other paid service!
Aug 17, 2017 | Dynex Televison & Video
Cable jack does not fit tv
It all depends on cable an termination. Outside an cable tv use F connectors. What type of cable are you using? There are also connector changers available also
Jun 22, 2014 | GE 34760 Passive Flat Panel HDTV Antenna
Which end is the receiving end of a house tv areial
peter_321
One end of the coax cable is connected to your antenna. The other end connects to a coax port on the back of the receiver labeled "TV/Antenna Cable In". All DISH Network receivers have this port on the back except our "K" series receivers. These receivers require a module to plug into the back of the receiver. Connect the antenna cable to this port, "TV/Antenna Cable In", if the receiver has the port available. I hope this helps.
Ray Calo
DISH Network
Mar 05, 2011 | Televison & Video
Where do you plug the antenna cable into a 50" pioneer Pop-505PG Plasma TV
on the back of the viera in the middle is all the jacks, at one end is a standard cable tv/antenna jack...just screw the cable into it, and then have your tv scan for channels.
'you should be good to go after that.
Dec 18, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
On the back of the VCR are two cable attachment
SIMPLE: the one that says VCR OUT goes to the TV IN , and the DVD OUT goes to the VCR IN , THANKS AJ
Aug 08, 2009 | Televison & Video
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Connect to Converter Box
There are a fews ways of accomplishing this.
On the back of your converter box and TV/VCR there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from the antenna to the (IN) connection on the back of the converter box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the convert box.
Step 3. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful. Please take a moment to rate tis solution.
Jan 19, 2009 | Panasonic Televison & Video
Digitial TV Converter
The antenna connects to the ant jack on the digital converter box. The cable you are describing goes from the tv jack on the box to the ant jack on the tv. If this does not work we will need more info. Hope this helps.
May 13, 2008 | Televison & Video
Hand held casio tv vs digital signal
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Apr 29, 2008 | Televison & Video
Color fades in and out of picture
The first thing I would check is the antenna or cable connection into the set. When an analog TV signal is weak, the first thing to go is the color, then the picture, then the sound. If you have another TV, connect it to the very same cable or antenna connection and see if it fails the same way, too. Make sure you just disconnect the cable end right where it goes into the failing TV and connect it to the other TV - don't disconnect the antenna cable from the wall for this check. If the second set does not fail, gently pull on the antenna wire - not too hard, you just want to put a little tension on it to see if it makes the color cut out. Reconnect the first one and try again. If it's fine now, the connection was loose. If not, it has a tuner problem that must be repaired. Also, when you look at the end of a TV connector, the center wire should stick out just a little bit, like in the attached photo. If it doesn't stick out as bit, it won't make good contact, and will result in a weak signal. I appreciate your rating if you find this helpful.
Nov 13, 2006 | Philips 27PT643R 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
