Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
The handles on the door do not align vertically. How can I access the mounting screws to adjust them? The directions that came with the frig are useless.
  • 316 Answers
There are no adjustment screws that can change the position of the door handles. They are in a fixed position and can only be tightened or loosened. YOu didnt include a model number so I cant tell if its a piece of trim that may not be in the correct position, or how to remove the handles to make sure they are secured to the door correctly.
Posted on Oct 13, 2010
How do I adjust the handlebars on a shogun trail breaker
The mount for the handle bars have a bolt to mount it and a bolt to adjust the wheel alignment on most bikes. The alignment bolt goes down through the vertical pipe to a wedge system that holds it to the desired height. Look carefully at the vertical pipe for the maximum extension markings.
Jan 23, 2015 | Cycling
Loose handle
There is a long vertical handle held to the door by two short horizontal pieces. Run your finder along the under side of the two short pieces and feel for a very small indentation under each one. Each one is a set screw with an Allen head. Insert a small Allen wrench (English not Metric -- I don't know the size, but it is probably the next to the smallest in the set) into each one and back them out (counterclockwise looking up at the screw). The big vertical handle should come off when you back the Allen screws out far enough Now look into the short pieces sticking out from the door. Inside each one is a Philips screw holding the piece to the door. Tighten those screws with a small Philips screw driver making sure that the indents on the front of pieces will align with the vertical bar when you put it back on. When the Philips screws are tight, put the vertical bar back on and tighten the Allen screws. If you have some Loc-Tite, you might use that as well.
Mar 11, 2013 | Marvel 6BAR-BD Beverage Cooler
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
InFocus LP600 - A vertical shadow on the Left-side covering about 20% of screen.
The light tunnel inside the "engine" is either out of alignment or the glue holding the tunnel together is coming unglued and 1 of the 4 sides has fallen in. There are 2 screws to adjust this if the tunnel is still intact. One or both screws can be accessed by opening the lamp door and then you have to remove a thin sticky cover. You will see 2 small screws that will have to be adjusted with a small torx (3) or allen. You will have to have the safety switch pushed in with something and adjust while the projector is on, using the most easily accessible screw, turn it towards the direction of the "banding". It should decrease. If not, turn the screw the other way. The screw that is not so easy to get to is for adjusting the banding the can appear across the top or bottom of the screen. If the banding gets worse or even starts to show diagonally across the screen, it is a good bet that the tunnel has collasped.
May 03, 2010 | InFocus SP-LAMP-019 Projector Lamp for...
I need to replace and then adjust the headlights on my 2000 Chrysler 300M. How do I replace the headlights, then adjust them.
Park your vehicle on level ground with the headlights near a garage door or wall. A good distance is 2-3 feet away from the wall or door. The location must be perfectly level and flat at a distance of 10 to 25 feet away from the door or wall.
Switch on the low headlight beams and mark the horizontal and vertical centerlines of each headlight beams on the wall using masking tape. This will mark the center of each beam with a +. The marking will tell you where exactly the headlight beams should be centered from a distance.
Move the vehicle back about 10 to 25 feet away from the garage door or the wall.
Keep the headlights on the low beam setting.
Use the markings you made on the wall or garage door to, check where the light shines and see if the centerlines still match up with the masking tape marks. If the centerlines of the two beams do not align with the tape marks, you can adjust one or both sides as needed.
Make the necessary adjustments with the lights still on while watching the light beams on the wall and your marks.
Turning the top adjusting screws in a clockwise direction will raise the beam while counterclockwise turn will lower it.
Turning the side adjuster screws will adjust the lights to the left or right.
Continue the adjustments until the center of the light beams are aligned with the tape marks. Then adjust the vertical alignment of both beams slightly below the marks on the wall. This will assure that the lights are tilted slightly downward so they won’t blind approaching motorist.
The will align bot lights, the high and low sine both are connected to the same headlight!!
Nov 18, 2009 | 2000 Chrysler 300M
My outside door handle isn't connected to the inside handle. i can't get in from the outside. :( please help? thanks. what about alignment problems? can you help with that? :)
remove door panel two screws on arm rest door handle/and panel clipped into place connector clip on rod to handle or lock damaged or missing look in bottom of door for clip if broken most auto stores carry part door alignment is hinges for adjustment wheel align unless u have the equipment leave that to the pros
Oct 14, 2009 | 1996 Chevrolet K2500
Kenmore 106.55526400 door handle needs mounting
Yes the door will need to be partially disassembled to reach the back of the screws. The handle is the lowest price I could find is at Sears Parts Direct CLICK HERE=> http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
Get an account and enter model number.
To see the photo of the door click here below
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0404023-00006.png
If you need more help please let me know. appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Trying to help but, Not sure you will be interested in the repair, Thanks, Sea Breeze
Aug 15, 2009 | Whirlpool ED2FHEXN Side by Side...
My passenger door hadle was pulled off when I pulled it to open it. I am trying to find a manual that explains to me how to change it. Can anyone point me in the right direction??? It's a Hyundai Tiburon...
These are the procedures outlined in the shop manual (without pictures). If you want the pictures too, go to http://www.hmaservice.com/ and register (by Vehicle VIN). Then you can navigate through the service manuals to find the info you're looking for. (You'll also have access to wiring diagrams, service bulletins, etc.)
1. Remove the grip handle using a remover.
2. Remove the inside handle housing.
3. Remove the tweeter speaker using a remover.
4. Remove the mounting screws and remove the door trim panel.
Disconnect the wire connectors.
5. Remove the door grip handle mounting bracket, speaker and door trim seal.
6. Remove the door tooling hole cover.
7. Remove the door glass stopper catch.
8. Remove the door delta chassis.
9. Remove the glass stopper bolts, remove the window glass.
10. Remove the door side weather strip.
11. Loosen the mounting nuts and remove the regulator assembly.
12. Disconnect the cable, after loosening the inner handle mounting screw, push the inner handle toward the direction shown in the illustrationand remove it.
13. Remove the door outside belt.
14. Remove the door outside handle and key cylinder.
15. Remove the door latch assembly mounting screws and remove the door latch assembly.
May 03, 2009 | 2003 Hyundai Tiburon
596.73502200 Refrig
easy, get the model number from inside the frig. go to sears .com put your model number in and you will get the whole diagram of your frig. and how the handles come off,i'am thinking if you don't see the screws you have a panel over them that will slide up or down to let you get to the screws ,let me know how you do-mike
Oct 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Microwave oven does not heat
Found brand & model in your other thread:
> Whirlpool Gold Microwave Model GH7155XHS
Did you see the door switch file at my site I pointed you to?
With the door shut, you gently loosen the door switch mount screw nearest the switch that is not aligned properly.
Then pull back slightly on the door switch mount, and while holding it back, retighten the screw.
The door switch mount is also called the latch board. On the exploded view, it looks like there may only be one screw.
You have to look it over and figure out how to adjust it based on the way it's constructed and which way it needs to go.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 20, 2008 | Microwave Ovens
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
56 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
