Question about Canon Pixma MP500 All-In-One InkJet Printer
Pixma P 500...printer will not print in black...prints colors fine...have replaced both black ink cartridges and run through the cleaning cycles. still won't print in black...help appreciated
  • 67 Answers
Would have to try by changing the print head as well
Posted on Oct 13, 2010
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
I bought a refilled black ink cartridge for my
Replace color cartridge.Printer can't print without color cartridge.In your case the color cartridge is failed.
Nov 24, 2009 | Canon PIXMA iP1600 Printer
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Using refilled printer cartridges in Canon MP500, how to reset
There is no way to reset it, you just have to watch your ink by the printing you do, Normally, black ink will last up to 500 copies or more if you put your printer properties on fast print (this is to save ink when printing from the Standard version). In Color, it may vary with the projects that you do. The way I check, when my cartridges to see if they are almost out, is to run the clean cycle under the printer utilities menu, then the printer test page. This should show you what colors, and black ink you have or dont have. When you recycle or reuse your cartridges, the metal component that is on a new cartridge for the printer to recongize the it, is removed during refill process. I dont why the companies that fill the cartridges do put it back. I wish they would it would may things alot easier. I hope this helps.
Aug 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
The black ink will not print on my canon pixma ip4200
printer head problem remove ink put about ten drops of alcohol in where the ink goes in run clean cycle ten times
Mar 29, 2009 | Canon Office Equipment & Supplies
Printing Problem
Look for ink clogged on the printer head. Run cleaning or deep cleaning after installing the new cartridge before printing. Take nozzle check print.
Apr 30, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
223 people viewed this question
old marine
old marine
