The F1 button of my laptop(Compaq) has come out which was based on two crossed clips. One of the clips is broken from the corner so it can not be joined again. Please let me know if i need get my laptop opened for it or it will be repaired easily... Thank you......
  • 2,567 Answers
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Posted on Oct 13, 2010
How to reset bios on compaq v2000 laptop
Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
I don't have the Quick Reference Guide for my Compaq Presario F756NR (may never have had it). I cannot figure out way each of the function buttons (F1 to F10) are supposed to do. And what is the f
Fn button is your Function button, you hold it down and it allows you to use the hotkeys that are usually colour coded the same as the Fn lettering. Stuff like brightness/contrast volume up and down. That kinda thing.
Jun 24, 2012 | HP Compaq Presario F756NR Notebook
How do I change the administrative password for my Compaq nc6220
  1. Press the Power button to start the computer.
    NOTE: Pressing F10 opens the BIOS of Compaq Presario desktops 2001 and earlier.Pressing F1 opens the BIOS of the S3000 series, 6400 series, and 2002 models of Presario desktop computers.
  2. Immediately press the F10 or F1 key repeatedly on the keyboard when the logo screen displays.
Oct 24, 2010 | HP Compaq nc6220 Notebook
F10=rom based setup
I have suceeded by pressing Fn Button + Escape while booting. When it starts beeping, keep the Fn-Button pressed and try F1 / F2 / F3 etc. till the screen changes and it starts booting normally. No idea why, but it worked. Good luck!
Feb 06, 2010 | HP Compaq nx6125 Notebook
Advice for Finding a CMOS Battery
Are there Radio Shacks in the UK? or try www.duracelldirect.com. I just saw it on Ebay for $2.49 and they ship overseas.
Cheers, hope it helps
Feb 21, 2009 | HP Compaq Evo n610c Notebook
IBM Laptop A31 2652 Garbled video even at initial boot screen
Connect an external monitor to the laptop, power up the monitor first and then bootup the laptop. The Windows image will automatically divert to the external monitor.
If the images is OK then the video card is OK.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Get back to me if you still have problems together with any error messages etc.
Jan 25, 2009 | HP Compaq Presario F750US
Compaq Presario Keyboard
Carefully! Make sure there are no screws at the back which hold it down, then use a guitar pick or small rubber sleeved screwdriver to pry one corner of the cover up. The clips are usually VERY tight as the cover is installed once and never usually removed again, but they do give with a bit of force.
Dec 31, 2008 | HP Compaq Presario C500t Notebook
I have a Compaq laptop. The clip that holds the 9 key on is broken. Where can I get replacement keys and clips?
Probably need a new keyboard altogether.
Some here.
http://www.priorityelectronics.com/laptop-keyboards/presario-keyboards.htm
http://www.sparepartswarehouse.com/Compaq,Laptop,Keyboards.aspx
Refurbished ones here:
http://rogerhenson.com/parts.php?db=11
Mar 18, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
