Question about Endurance T8 Hrc Treadmill
What does an error e6 mean on an endurance treadmill? Is it something I can fix myself or do I need to call a repair place? Is it a problem that can be fixed for a reasonable price?
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: How do I fix my Endurance Treadmill TF3i Err7
Unplug unit remove motor shroud check connections on lower board (incline board). I believe their is a 3 amp fuse in circuit check with multi meter to see if open replace fuse power up unit and if it blows the fuse then replace incline motor and if not, then use engine mode press stop then Incline + or - to force incline up to max incline then bring it down to 0 then turn off power then wait 10 seconds then hit power on then if error does not appear then hit start and resume using unit. If the procedure above does not activate unit then replace board.
Posted on Apr 16, 2010
I have an Endurance T10 Treadmill with an error code of E7. Any ideas what I can do?
If you wish to get some details about treadmill error codes and solution ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 27, 2017 | Endurance Exercise & Fitness
On the bremshey treadmill, what does the code E6 mean?
If you wish to get some details about treadmill repair and error codes; check the site linked here. Pull up older posts.
Sep 22, 2016 | Exercise & Fitness
What does E6 code mean?
If you wish to get some details about treadmill error message and repair then check the following link
Aug 19, 2016 | Exercise & Fitness
MY AF 843M AEROFIT TREAD MILL IS SHOWING AN ERROR E1 AND SOMETIMES E6. KINDLY GIVE US THE SOLUTION
You have to check the Speed sensor and its position.Normally you will find the speed sensor near motor pulley. In almost all treadmills E1 Error is related to speed sensor.
If you wish to get some details; check the site linked here. Pull up older posts.
Jan 04, 2014 | Exercise & Fitness
What does an E3 error code mean on my vitesse endurance xt treadmill
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working replace see the diagram attached.However clean it. and tight the connector very well.God bless you
Apr 03, 2013 | Exercise & Fitness
Error6 on my treadmill
please see the problem and fix it. see the block diagram
circuit diagram attached.
Happy new year. God bless you
skfsyaaaaaelftksuqmcc
Jan 01, 2013 | Exercise & Fitness
Kettler pacer show the error 1
Dear Sir:
You can be fix it.
1) See the diagram attached, and adjust it, clean, and tigh the wire connector very well.
2) Test the input voltage for motor, if there are voltage, the motor need repair.
3) Test the output voltage board, for the input voltage motor, if there are NOT, the board is faulyt.
4) However RUN the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 05, 2012 | Endurance TF3i Folding Treadmill
What does error7 mean when I turn on treadmill
there are 2 options with this error:
1) The elevation motor: Run the software calibration for diagnose, troubleshooting, and fix it. a) lube the gear and shaft very well b) adjust the potentiometer c) test the motor if o.k or faulty d) see if relais for up and down is clean the contacts.
2) Display board: adjust the reed switch see the diagram attached.clean, tigh the wires connector.
May 02, 2012 | Endurance TF3i Folding Treadmill
My lifespan treadmill has error code e6, what does this mean?
hello,kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you for using FixYa,Thanks,Reymond
Oct 19, 2011 | Exercise & Fitness
What does error 1 mean shows in incline window. happens at start, belt doesnt start after countdown?
error 1 simply means no belt movement generally. If belt moves a little it could be the speed sensor but generally it's the motor controller.
Nov 16, 2009 | Endurance TF3i Folding Treadmill
Endurance T8 Hrc Treadmill Logo
Top Endurance Exercise & Fitness Experts
Electro Med Services...
vinayghl
Ron Dufek
Ron Dufek
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
