Question about Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter
Whats the difference between the taveler plus and the traveler plus HD other then 25lbs. The specs look the same and the weight is the same
  • 692 Answers
Well you got it the difference is weight capacity the HD will support 25 more pounds than the plus Hope this helps
Posted on Oct 13, 2010
  • BingoK1 May 12, 2011
    But WHY does it support 25 more pounds?? What, mechanically or structurally, allows it to do so?
Whats a 2006 petrol v8 landcruiser 100 series weigh ?
weight specifications
Unladen Weight 4949.4 lbs OR 2245 kg Gross Weight Limit 7187.1 lbs OR 3260 kg
TOYOTA Land Cruiser 100 specs 2002 2003 2004 2005 2006 2007
Jan 16, 2018 | Cars & Trucks
2001 FXD - What are the specs for front fork travel and how do I change the oil if needed in the fork tubes?
There are no specs for front fork travel. The forks will travel from full compression to full extenison. Use Harley type E fluid.
Sep 17, 2014 | Harley Davidson FXST Softail Standard...
Pride go go elite plus stops when going up inclines
batteries heading for replacement, to much weight, controller fault, are the most lightly suspects.
Aug 19, 2013 | Pride Go Go Elite Traveller Plus HD 4...
Chassis buckled on babystyle oyster travel system
Try ebay I can usually find all sorts of replacement parts or someone selling the whole thing cheap so you can use what you need
Apr 05, 2013 | Babystyle Oyster Travel System Includes...
I am travelling by air next week and I need to know the serial no. of my scooter. Where do I find this. I have a 4 wheel Go-Go Elite Traveller Plus Hd
hi , its located on the bottom part of the seat stem , you will need to remove the seat and battery pack to see this,
Regards
Jan 25, 2013 | Pride SC53HD GO-GO Elite Traveller Plus HD...
Gogo 4weeler clicking niose going up hills
check the duudrff keys used to hold he wheels in line with the axle. i had a clickin nosie inm y three wheeler and it took several trips to the shop and 4 different motorsbefore we discovered the keys where too thin.
Oct 28, 2012 | Pride Go-Go Elite Traveller Plus HD...
Harness on graco tavel system broke where can i get one model number 7537TABU
You can order replacement parts for the Graco travel system on Gracobaby.com:
http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
You will need the model # as well as the date of manufacture.
Oct 08, 2012 | Graco Alano Travel System Stroller & Car...
Looking for the torque specs for the pressure plate just replacing the clutch
15-25lbs there should be 6 bolts apply lock tite to bolts and then tighten them all down till they are seated. Pick a bolt(call that bolt #1) and torque it then in clockwise motion skip over the next bolt(bolt #2) to the third bolt(bolt #3). Torque bolt #3 and skip over bolt #4 to bolt #5. Torque bolt #5 and then go to bolt #2 torque it and move to bolt #4 and torque it the last bolt to be torqued is # 6. then go around and do it again to make sure they are all the same. This is how the manufacture says how to do it you can do it anyway that works for you as long as they are all torqued the same and they are between 15-25lbs. If bolts are new I would take them to 25lbs if they are the lod bolts I would stay closer to 15lbs that way you dont snap them off.
Sep 19, 2010 | 1986 Ford Ranger 2WD
Why Fry - 220 or 110 ????
You should be fine with this. Here is the spec:
Quartz lock large blue LCD display showing: speed, pitch & platter direction, locking platter reverse button, located in battle position, 3-speed design: 33, 45 & 78 RPM, 7 grams of anti-skate adjustment, adjustable pitch control+= 10 & pitch bend buttons, locking reverse button, hi-tech tone arm with height adjustment, feather-touch start/ stop control, strobe illuminator, pop-up target light, headshell, slipmat and dustcover included . 115V/230V switchable. 17.75"w x 6"h x 14"d. Weight:27lbs.
Jul 18, 2010 | Gemini PT-2410 Turntable
Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter  Logo
161 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
