Question about Hussmann Refrigerators
I am working on several hussmann innovator series frozen food glass reach in doors at a local grocery store in the Phoenix area. These doors will not close by them selves. I removed the torque rod assembly, they are not broken. When I use my wrench to adjust the torque rod, it turns but does not tension the door.The piece that holds the tension on bottom of case and end of torque rod are not stripped. Seems the end of torque rod inside of door is not being held. What gives?
MicrowaveSvc
  • 9047 Answers
SOURCE: Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Posted on Nov 15, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Posted on Dec 05, 2006
cammedic
  • 667 Answers
SOURCE: Broken Battery Door
I would think a call to Fuji would be in order: 800-755-3854
They should be able to sell you a new battery cover
Posted on Mar 28, 2008
aborcass
  • 2651 Answers
SOURCE: cleaning inside glass door, kitchenaid range
you do no tneed to remove the top to release the glass, yea aslong as the lower trim is removed then the only thing holding the glass, is the grease/sticky rubber gaket. lift up from the bottom slightly and twist out from the tabs. just be carefull when cleaning inner door glass, those "ridges in the paint, are just that paint, so dont use anything abrasive, youll ruin the finish!
Posted on Oct 30, 2008
SOURCE: GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Posted on Jan 28, 2009
4 Which are the best espresso beans I can find in virtually any food store?
I agree with the fact that it is hard to find best espresso beans in the grocery store. If you are going to buy from the grocery shop find out if they stock any regional coffee roasters. Local coffee roasters will tend to be fresher and come with the added bonus of supporting the local economic climate.
Sep 04, 2014 | Koppers Dark Expresso Beans 5lb 983
Tip
Cleaning residual candle wax off glass
Believe it or not you can get dried candle wax off of glass with a MISTER CLEAN MAGIC ERASER!! You can use generic erasers , such as Home Depot or your local grocery store. It works !
on May 23, 2015 | Crafts & Hobbies
If you have a home garden, and you grow more than what you can use, what do you do with the extra? Do you give it to friends and family or do you give it to those in need by way of food pantries at...
I have too many vegetable plants in my garden and I give some of the vegetables to needy people who starve as its a great work and you should also do the same.
http://www.gardeningnorthside.com.au/tree-removal-north-shore/
Aug 26, 2013 | ValuSoft Your Complete Landscape and...
Are there alternatives to buying fish food? Can I get stuff from my local grocery store?
There are specific foods that you can buy when you are doing your own grocery shopping and feed it to your fish, but you have to be careful that it's appropriate or you could kill your fish. Here's an article that gives suggestions about the kind of fish foods you can substitute. http://www.aquaticcommunity.com/fishfood/alternative.php
Aug 26, 2012 | Archos Fish
My dishwasher is leaving food and lime on my dishes. I have cleaned it with a cleaner and by hand several times and still have a problem. I have had other dishwashers that didn't do this. Do you have a...
It may simply be the new phosphate free dishwashing detergent. Check your box of detergent to see if it is now phosphate free. I had the same problems - white film, food particles - with no changes in my dishwashing habits. Turned out to be the new restrictions on phosphates in the detergent. I found a product at my local VONS grocery store called "Lemi Shine". It's crystals that you add along with your detergent. It works great. Also might be sold at Walmart.
Mar 06, 2011 | Maytag Dishwasher
Is it okay or not... freeze meat, thaw, grind, refreeze
Yes, that would be okay. I do that all the time with my meat.
Thanks -Oscar
Mar 05, 2011 | Computers & Internet
We have a kitchenaid superba oven glas top and i like to clean it but i do not know how can you help me e-mail me at
Purchase a cleaning spray. Easy-Off Glass Cleaner, Windex or Drackett Glass Cleaner are all available from local department or grocery stores. You could also use dishwashing soap. Any non-abrasive, bacteria or grease removal product would clean glass cooktops.
Spray the whole cooktop area. Allow the cleaner to sit for about 2 minutes. If you have stuck-on food, spray only that portion of the cooktop. Let the liquid sit for approximately 5 to 10 minutes.
Use hot water. Soak your sponge and wring it out. Wipe down the glass cooktop. Carefully scrub the stuck-on food. Run the sponge over the spot area at least 20 times to remove the food. Wring out the sponge and rub the remaining portion of the glass countertop
Use a terry cloth rag to wipe down the cooktop. This will remove excess water and soap.
if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Jan 01, 2011 | KitchenAid KEBS177 Electric Single Oven
Soap scum on shower doors
We definitely want to stay away from any cleaning products that have an abrasive. Your local grocery or department store will have products specifically for cleaning soap scum. Some products will work better than others depending on the type of mineral content in your water. The best product is one where you don't have to do an excessive amount of scrubbing to remove the hard water and soap scum stains. Be sure to follow the manufacturers instructions for the best results. Again depending on the mineral content of your water you may have to try a few different products until you find one that works the way you want it to. There are also products you can purchase that you would spray onto the glass after a shower to prohibit the buildup of soap scum.
Jul 24, 2010 | RTO Shower Enclosure, 6mm" Tempered Glass,...
My 8 ft Hussmann freezer is working, but not cold at all
Unfortunatly, your repairman is correct. The evaporator section (part that makes things cold) of this case is build into the wall and if it is leaking it is not repairable.
Dec 17, 2008 | Hussmann HUS-LBN8 Self Contained Frozen...
Refrigerators Logo
46 people viewed this question
Top Hussmann Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Hussmann Refrigerator Expert? Answer questions, earn points and help others
