Question about HP Pavilion zd7000 Notebook
Good morning, have ph zd7000 with no power fan did not come on but have 18.5 vdc goning in. Help
2 Suggested Answers
  • 18 Answers
SOURCE: http://pinouts.ru/Power/atx_v2_pinout.shtml
um what you want lol:?
Posted on Sep 07, 2009
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
I have a 1996 grand am gt v6. While driving this morning the heater fan slowed and the battery light came on. tested the Battery and it was 12.5 vdc not running, but running it was 11.5 vdc. I think it...
Yes it is the alternator, running should have no less then 13.5 volt's, not running your voltage was battery volt's which was good voltage, running was less due to battery running every thing and not the alternator, replace it will be fine.Hope this was very helpful.
Jan 19, 2010 | 1996 Pontiac Grand Am
What is the output of the charger for the B&D cordless drill 9049a?
The output power will be higher the the battery itself, a 14.4V will be up around 16-18 Vdc. an 18 V will be 20-21 Vdc. Now this is if your testing it with a multi meter and it is not under a load.
Dec 14, 2009 | Black & Decker Drills
My ac adapter seems to have gone bad on my CLT1554 model lcd tv. can I find a replacement?
check the adaptor it will say like 120 ac to 12dv at 1000 ma this what your looking for or go to the back side of the tv like mine says 12 to 18 vDC I think as mine I could run on my car Battery, but power supplys are UL most likley rtatyed and have the specs on the in today tech world power supplied TV or 12 DC and laptops 18-21 vDC when the use LCD technoligy......1000ma =1 amp
Jul 03, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
On/off switch on zd7000 laptop
That fans is not fited in your laptop once again cheak the fans settings and virfy the your switch
Jun 15, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
