Question about Brother IntelliFax-2820 Laser Fax
Paper wont feed from drawer - Brother IntelliFax-2820 Laser Fax
    Problem Solver:
  • 13 Answers
Clean the pickup roller with wet cloth
Posted on Oct 13, 2010
It wont print on heavy paper
You may have to use the manual feed tray on the side of the copier. It is not designed to run through the paper tray, to many bends....Good Luck
Mar 08, 2013 | Toshiba e-studio 203sd
Paper will not "feed" from
this is an issue with the papper feed and pickup rollers if it is not taking the paper from draw you need to replace the pickup and feed rollers also check the paper feed clutch if no good replace as well
Also make sure also make sure the paper is being lifted up when you close the draw you should hear the tray lifting the paper up to the feed system
Feb 17, 2011 | Minolta EP4000/5000 CS/PRO Copier
My Mita DC 1860 is showing that the lower A4 drawer is out of paper yet the drawer is full. I have on done the drawer and checked for paper fragments after a jam. All has been vacuumed thoroughly. I'm...
On the cassette, there is a floating plastic piece that is on a hinge so it can swing up and down. This arm is supposed to come in contact with the paper as it is raised, and depending on the elevation of the arm, it will display the paper amount. This would be the first suspect for me, I would physically look for this plastic arm and ensure that it is free swinging and does not stick. Also, open and close the drawer and listen closely for the lift motor to activate. If you hear the lift motor, then you most likely have a problem with that plastic piece.
-David.
Nov 04, 2010 | Kyocera Mita Office Equipment & Supplies
Can't get top feed to sense paper and copy, it will copy from bottom
the reason for this could be that you have run the feed tires and seperation tires bald by only using the upper paper tray. i would suggest getting the feed tires replaced and that should fix the problem. you might also check behind the paper drawer to make sure that a piece of paper did jam and get shoved up behind the drawer and is keeping it from working
Jun 11, 2010 | Sharp Office Equipment & Supplies
My Canon 5050 bottom drawer came out, an arm inside has popped up and we now can't close the drawer. We've can't gently put the arm back down. How can we get the arm down again?
Prior to the issue you facing basically ,you check whether u can reattach the arm or you can try to compare with another drawer to figure it out .See anything that broken or crack pieces.Kindly post pic to me ,I'll might help u.Thanks ,pls rate me!!!!
Sep 20, 2009 | Canon Office Equipment & Supplies
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Letter Drawer 1 on Model IR5020
look behind tray for paper preventing the feed rollers from knowing there is paper there
Feb 18, 2009 | Canon imageRUNNER 5020 Copier
Paper drawer won't slide out
Jane,
I understand that you mean the paper tray that wont come out correctly. If yes, simply open the paper jam clear cover on the back side of the printer and push the paper feed roller inwards and take the paper tray out the same time.
If you mean something else, please post here as a NEW post (this horrible system of fixya doesnt send me nearly any mails when another post is added!)
Jan 06, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother IntelliFax-2820 Laser Fax Logo
138 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
