Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is fine, but refrigerator side is warm and NOT cooling. Door was not left open, etc . Top interior light was not coming on and was extremely hot to the touch, but is now coming on (did not change or do anything except open and close the door several times.
  • 1,531 Answers
This problem is usually caused by excessive ice build up on the evaporator coils.There also a chance that the evaporator fan in the freezer compartment is not working this is how your fridge gets cold.if there is ice build up on the evap coils there may be a problem with the defrost heater or timer.there is a door damper located in the rear of the fridge compartment that needs to be check for anything that may be obstructing the operation of the door.
Posted on Oct 13, 2010
Gsc3pgxcfss warm fridge, freezer working fine, lights off in fridge
James, not sure I understand your message when you say both lights go off, but later say lights begin working. Do you mean they go off when you push the buttons at the door? And when you say no cold air comes from the freezer, is the freezer door closed? See if air begins flowing with freezer door open. If so it would indicate the return air path from the refrigerator to freezer is blocked.....damper staying closed or evaporator coil frozen up. The return air path has to be open to allow the freezer to keep sending out cold air to refrigerator when freezer door is closed. You might thoroughly defrost to make sure coil is not frozen.
If the door button for the refrigerator light is bad it can signal that the door is open all the time, so the freezer will never send cold air to the refrigerator. And that will be good news. Door switches are cheap. If you don't have a volt meter and know how to check switch, just remove the door switch from the refrigerator, leaving wires dangling, and close the door with a thermometer inside to see if it begins cooling (or just wait a while) I had that problem a year ago and was happy to find a bad door switch. More often it's a frozen coil, and that can be more expensive to fix. Sometimes you can discover a bad switch by pushing in the door button and the light stays on, but it doesn't sound like your situation.....sounds more like a frozen coil. If so, maybe all this extra information will help someone else.
Mar 23, 2014 | GE Profile PSW26P Stainless Steel Side by...
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Refrigerator not cooling FRS22WNC
the damper vent door between the freezer and refrigerator isn't opening to let cold air into the refrigerator compartment from the freezer side,its in the upper left corner in the refrigerator behind a grille,if its closed you wont feel cold air flowing in from the freezer sometimes you can shine a light in this area and look in the other compartment and if no light then the doors shut and this is why its not cooling the refrigerator
Sep 29, 2012 | Frigidaire FRS23H7C Side by Side...
Refrigerator cools poorly but freezer is OK, what's the solution?
There are various reasons which can cause this. They are
  1. Interior sweating.
  2. Bad door seals.
  3. Excessive door openings during hot humid weather.
  4. Storage of excessive uncovered liquids especially if they are inserted into refrigerator while warm.
  5. Void in insulation.
  6. Overcharged.
  7. Bad door seals.
  8. Condenser fan not running.
Jun 21, 2010 | AEG SK71840-4i Top Freezer Refrigerator
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Referidgerator side is not cooling?? Help?
I had this problem. Here's what I found: The cooling core on the freezer side was froze up. Covered in ice. I think the reason this happened was that the freezer door was held open by one of the slide out trays just enough to pull in outside air. Don't know how long it was like this. When I found it (and corrected it) the interior of the freezer was covered in ice crystals. From then on the refer side contents began warming up. There was no flow of cool air to the refer side from the freezer side (this cool air comes in from the freezer side fan near the top left side of the refer side). Freezer side was near zero temp and the unit ran continuously. Here's what I did: Removed everything from both sides (put it all in another fridge/freezer). Turned off (or unpluged) the fridge and left it off over night. I put towels under the fridge because there can be an over flow of water that could go to the floor. It works great again.
Nov 03, 2007 | Jenn-Air JCB2389G Stainless Steel Side by...
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
103 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
