Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv won't turn on
At first it just had a distorted pic when it was turned on after a while it would clear up. then one day i turned it off and now it acts like it's going to turn on but no pic comes up it just clicks on then goes off after about 3 sec.
  • ebbemann Jun 07, 2008
    will not turn on
  • gcue44 Nov 08, 2008
    tv turns on than off
How do you get the board removed ... i have the back off and don't want to destroy anything ... think this is my issues also
Posted on Aug 17, 2008
Just recantly got same tv give to me and had the same problem i am by far a tv tech but i tore into it anyways. finally found the problem and ive read about alot of the same tvs having similar problem so i was thinking might be a factory fault. if you take off back panel look on left side there will be a circuit panel and in the bottom left area there is a small grey box not sure what it is.
the numbers on mine are R73 kp F4 QR21520 0087 fh 2000 vdc
might not be that exact order. but i removed the board and looked at the bottom of it and found a bad solder spot i just bent the wire to get connection and mine works
hope this helps
Posted on Jul 31, 2008
It could be a blown fuse , check that 1st - you have to pull open the back of tv to find it- but if it is the fuse its only 2 bucks to fix
Posted on Jun 08, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Tv pic has redbluegreen images pic distorted
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs or defective ICs. If you feel that you want to attempt the repair yourself, please update this with that indication and additional details and instructions will follow. The parts for this repair will run about $40-$60.
Dan
Dec 10, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Color distorted. when turn it on it immediately
mine did this we spent almost $600 before resolving the problem SORRY
Aug 16, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Picture is distorted on my Sony Grand WEGA KDP-65WS550 65 in. Rear Projection HDTV Television
Can you paste snap of distorted picture of tv here to understand what kind of distortion is this.
Thank you.
Sep 09, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Video appears distorted--halo like
check your sharpness setting, it should be very low and even in the negatives possibly on a plasma. I was told the sharpness option was for crt tube tv's anyway
Jan 05, 2008 | Panasonic TH-50PX75U Plasma HDTV
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
Distorting
if it is wavy lines across the top it is probably the scan converter/ hyper bd they are becoming hard to find/expensive you can repair them but it requires many surface mounted capacitors and requires some VERY skilled soldering.
Apr 23, 2007 | Toshiba 57H82 57" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
