Question about Swintec 7040 Typewriter
When I turn on the Swintec 600 it will go to the far left side, but when you hit the return button, it will not return to the left side, but stops in the middle.
  • Swintec Master
  • 3,594 Answers
If it dosen't make a growling sound th L. margin is probably set there. Go to that point touch but don't hold thr MAR REL key, backspace to desired location, press L. mar. key. If it growls put a little WD40 on the silver shaft that the carrier slide on.
DickyO
Posted on Oct 18, 2010
It will not advance up when hitting return (but will return to the left side). Carriage/Roller is very tight when manually turning.
Either there is a bind in the platen (roller) or there is a piece of paper or other object caught in the feed rolls.
Nov 04, 2013 | Swintec Refurb 1146 Cmp Typewriter...
Swintec 2600-My cartridge is stuck on the left side -making a continuous beeping noise-how do I fix it
Look for debris in the area left of the printhead, anything that stops it from going all the way to the side frame.
DickyO
Aug 05, 2010 | Swintec Office Equipment & Supplies
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 29, 2009 | Swintec 7040 Typewriter
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
Swintec 640 margin release
If it is the left margin, you touch the carriage return button to find the current position of the left margin, then touch the mar release button and backspace to the new left margin location, then depress the left mar key. You should here a beep. You are done.
Jul 22, 2009 | Swintec 7040 Typewriter
MX600 Logitech laser cordless mouse, left button stops working
Just found a temporary solution (fixes the immediate problem, but it does return):
Turned the mouse off held down both buttons, turned it on, let go of both buttons. When you let go, it works again.
Jul 02, 2009 | Logitech MX 600 097855036162
Working with automatic centering feature
set both the left and right margins where you want them and starting withe the carrier at the left margin turn on the auto center then type, when you then hit the return button it will type centred between margins
Dec 07, 2008 | Swintec Office Equipment & Supplies
Swintec 7040 Typewriter Logo
71 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
