Question about Sony Audio Players & Recorders
Hello, I have a Sony Mini Hi-Fi Component System MHC-WZ5 and recently after inserting a CD disc (I've tried several original ones), I get the message "CD No disc" after after 5 'flashing' Reading attempts/turns whereby it then just stops. What should I do please? Thanks, Ed
  • ed_garsia Oct 13, 2010
    Hi Stelios,
    Appreciate the prompt response.Yes, I thought that was the problem. I had already tried the dry cleaner disk and still the same problem. I then tried wet with this solution you mention that came with the cleaner kit - still no effect. I then tried cleaning the laser eye but it was too difficult to get too and I tore a ribbon cable unfortunately in the process. Never mind, I plugged in an external CD player as a workaround.
    Thanks and regards,
    Ed
    President:
  • 1,851 Answers
Since this problem occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Oct 13, 2010
Cd player say no disc when disc is in. (sony mhc-ec691) how to fix
you need a CD head cleaner try Best Buy they usually have one cheap it's a CD with little brushes on it
Dec 31, 2014 | Sony MHC-EC69I Mini Hi-Fi Music Shelf...
Sony MHC-S3 Mini Hi-Fi component system
Correct the laser is not reading the disk. Cleaning won't help. Usually not worth getting repaired as a similar new unit will cost about the same!
May 25, 2014 | Audio Players & Recorders
MHC-GN1300D Video
I need to unlock a Sony mhc 1300D mini hi fi component , make it to play all the region
Oct 24, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
Sony Mini - Hi Fi MHC - EC55 won't play CD's. Says it is "Reading" then says "No Disk". I have used lens cleaner and reset factory settings. Any ideas
If you've already tried to clean the lens then with no improvement then its down to the laser having failed.
In some cases these are availble as a replacement part but aren't normally cost effective.
Jul 11, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
User Manual for Sony 2 box Mini Hi Fi model MHC W 25
http://www.sony.com.au/support/product/mhc-wz5
This is the closest I could find. Download from the above link (Open or Save)
Mar 25, 2011 | Audio Players & Recorders
CD burned on my computer won't play back on my Sony Mini Hi-Fi Component System MHC-NX1. I'm using Memorex Music CD-R and the burned CD will play back on my other stereo systems.
you have probles with a driver try to unistall the driver on the cd or dvd burner and automatic it will install the driver the pc will look for the driver on c:hdd if the porblem continue call 956 400 4141 I'm a computer technician send me you info and i will repair you computer problem.
Nov 27, 2010 | Sony 720W 5-Disc Mini Hi-Fi Component...
I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
Nov 25, 2009 | Sony Audio Players & Recorders
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
210 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
