Question about ViewSonic VX2245WM LCD Monitor
The screen will randomly start flickering and go black. Can someone please help!
  • Louis Ebert Oct 13, 2010
    jordyn298, do you see anything on the black screen? May need to point bright flashlight at screen (1 inch) and look very closely for faint image on the lcd panel. Tell me what you see or don't see. Is unit in or out of warranty? May need to ask Viewsonic if "cash+old unit" swapout is option for you. Is your pc functioning ok with substitute monitor? Are you playing "high speed graphics intensive" games" 12fixlouie
  • 11,361 Answers
Look for bad caps with leaking/bulgting topd first, worst case will be the lamp assemblies.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 13, 2010
LG LED TV, model #50LB5900-UV has flickering screen. Need advice on part replacements.
It is a very common problem for LG LED TV, the problem is defective back lights LED strip. You need to open the display panel, find the burn out strips & replace it (them).
Jul 31, 2017 | LG Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Flickering screen Toshiba P105
Flickering, always cause by LCD cable. Change it at any computer shop or service center and its not so expensive
May 08, 2010 | Toshiba Satellite P105-S6104 Notebook
It's a little over a year old. The screen will randomly start flickering and gets really dark and I can't see very well and sometimes just goes black altogether. It is very frustrating and sometimes when i...
Sounds like a loose connection at the inverter board. Laptops use an inverter to step up voltage to drive fluorescent tube(s). The problem could be at the inverter or at the tubes.
Mar 12, 2010 | HP Pavilion dv5-1125nr Notebook
Help SLV-900 has a screen that randomly flickers and wont play
Advice given has helped me to sort out this problem thanks
Mar 07, 2010 | Sony SLV-D100 DVD Player/VCR
Screen problems, help!
let a Pc engineer check the flex for your, it is a flex problem. good luck
Sep 15, 2009 | Lenovo 3000 N500 Notebook
Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
not to get to concerned just yet, a few tips, when you press on the top of the laptop case by the screen area in the back of the laptop do you notice the screen flickering off? and when you let go dose it come back on? if so this can be a faulty wire or bad inverter, they are actually both very simple to fix and relatively cheap fixes.
Aug 20, 2009 | Dell Inspiron 1100 Notebook
HELP ME FIX MY MONITOR PLEASE
same thing is happening to me except when i turn on my computer, you can see the screen and its flickering then a few seconds later it turns all black.. :( !!
Dec 04, 2008 | Computers & Internet
Plasma Problem
It could be the Logic board or/and one of the Logic Scan board failure. Parts availability depends on maker and may cost any where between $250 - $500. Labour depends on shop. Hope that'll help you. Good luck.
Jan 26, 2008 | Televison & Video
ViewSonic VX2245WM LCD Monitor Logo
150 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
