Question about Sceptre X42GV-Naga 42 in. LCD Television
I have a sceptre naga x42 lcd tv, everytime i turn it on, the standby light goes from red to blue, the tv powers on for two seconds, where i can see fuzz on the screen, perfectly normal, then the screen goes dark but the blue light remains until i turn the tv off and if i turn it on again, same thing, good for two seconds then nothing... any ideas as to the problem here...
  • Sean Strojny
    Sean Strojny Dec 08, 2013
    I have a problem kind of like yours. I plug the tv in and it goes from red to blue when I hit the power on. However i can not turn get the ligth to go back red by powering it off i have to unplug an repeat it does the same thing. When i turn the power on the light changes to blue but the tv still does not turn on. Is this a problem with the main board as well?
    New Friend:
  • 26 Answers
The problem is the main board i change the main board and the set came on
Posted on Mar 14, 2013
    New Friend:
I have a sceptre tv x42 I lost my cord don't no where to buy another one
Posted on Dec 05, 2012
4 Suggested Answers
SOURCE:
budmrtn
  • 11361 Answers
SOURCE: I have x42 Sceptre LCD tv and I have forgotten the
Download the user manual here to figure out how,
http://tv.manualsonline.com/search.html?m=&d=&q=Sceptre+x42
Posted on Nov 13, 2009
  • 27 Answers
SOURCE: Sceptre x23BV-naga 23" LCD HDTV needs a digital tuner replacement
just get a hd standalone tuner and hook it up to one of the inputs. way cheaper solution.
Posted on Apr 09, 2010
ArnelM
  • 184 Answers
SOURCE: We have a Sceptre X42
possible T-con problem but check LVDS cable first and don't forget checking capacitors from the power supply board
Posted on Jan 31, 2011
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
My x42 screen turns blue for a few seconds and then from the bottom of the display it quickly blanks. You can still hear the sound but the picture remains blank. I have tried to change sources but it...
The problem can be bad backlight inverter board or it is not getting the 24vdc from the power supply. Look inside to see if it has bad caps with bulging tops. Also check the power supply output voltages, you should have 5vdc, 12vdc, and 24vdc.
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Sceptre+X42GV-Naga&stock=all
Jan 05, 2010 | Sceptre X42GV-Naga 42 in. LCD Television
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre naga blue screen when tv on then turns blank, sound on
i have a secptre t v turns on for a sec and screen is blue then goes to blank screen can anyone help
Apr 18, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
I have a 32 inch sceptre naga. when i turn on a tv, the blue screen appears for less than a second and then goes blank. the sound is still on. what could be the problem
mine does the same thing, before... it would come on when i turned it on & off. But now it blue screens then blank black. Blue means if it stays blue & i turn on my computer it will show all the computer stuff, i have not used TV yet.. But if you can get it to stay blue you can change things with the cc control, or swap..
If you find how to keep it blue let me know please..
Apr 17, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
32" Sceptre LCD No POwer
0939a31.jpg This is the same problem I am having with my Speptre X20WG Naga Monitor.
The power LEDS are usually red in standby and blue in opp; but now they just go purple and nothing happens..no sound no picture. I called tech support and no dice they just wanted my money, but I think all we might have to do is change a fuse on the main pcb! As you can see the white arrow isnt really pointing to anything specific! I think the fuse is the lt blue component, but am not sure. This is all I can offer! If you gat any good tips or if anyone else finds a fix please email me pbj0327@yahoo.com.
Thanks! and good luck m007!
Nov 28, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
New Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
Aug 28, 2006 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X42GV-Naga 42 in. LCD Television Logo
809 people viewed this question
Top Sceptre Televison & Video Experts
leeboy3909
Level 1 Expert
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
