Question about Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP AF for Nikon Digital SLR
Hi, The zoom ring in my Tamron 17-50mm f2.8 has become loose... it rotates all the way and does not stop at 17mm or 55mm.. it gets stuck at some point suddenly and then I have to pull out the lens from the front to zoom in and out.. Could I fix this on my own? Please let me know Thanks, Andy
cammedic
  • 667 Answers
SOURCE: Tamron lens and canon speedlite compatibility
Your question is posted under a Nikon version of this lens. I assume you are talking about using the Canon EOS mount version.
The short answer is: Yes
Posted on Jan 15, 2008
cammedic
  • 667 Answers
SOURCE: Tamron 28-300 loose lens parts
The way in to this lens is from the rear. You'll need to remove the trim ring inside the mount and free the electronic connector from the mount ring before you remove the mount ring itself.
Posted on Jan 19, 2008
cammedic
  • 667 Answers
SOURCE: tamron 28-300mm lens disassembly help
Both, But start at the rear to remove the electronics and the outer barrels. Remove any rubber grip to expose 'hidden screws'. I would mark everything or document with pictures during disassembly.
Posted on Jan 29, 2008
SOURCE: Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Posted on Jul 05, 2008
SOURCE: ERROR 99
try cleaning the lens contacts of your lens and camera.
Posted on Aug 13, 2008
Jammed lens
Send it to Nikon for repair. If you try to fix it yourself, you will only cause more damage and add to the cost of repair.
Apr 04, 2013 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
Nikon 18-55mm lens will no longer zoom to 55mm.
there must be a problem with the lens ring which are fitted inside, occasionally it gets worn out because of improper handling . alignments may have caused you the problem. but once again you need a professional help because you wont get any elements or parts easily except from the company.this lens could also may have jammed due to any reasons, may be a foreign body or so and because the af is OK you are still getting a sharp image up to actual 45 mm which you think to be 55mm. If i were you then I would have inverted the lens and tapped gently and then check it once again or best goto Nikon service centers .
Feb 06, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Aperture won't go below 5.0 even when zoomed all the way out to 18mm... help!
Hi, did you get any solution? I have exactly the same problem with my nikkor 18-55mm f/3.5-5.6, my f/ won't go below 5 even if it is all zoomed out
Feb 07, 2011 | Tamron 18-200mm f/3.5-6.3 for Nikon
Tamron 17-50 loose ZOOM ring (not Focus ring or Front Element)
the same thing just happened to me like 3 days ago. The zoom ring was kinda sticky and then all of a sudden it just spins around and doesnt extend the barrel at all.
Nov 16, 2009 | Cameras
Canon EF-S 17-85mm - Stuck Zoom
this lens has a design shortcoming in it's aperture's ribbon cable ,the cable will rupture after around 1 year using, this problem taken place in more than 60% of owners with this lens. Canon has no respons with it problem and ask you send to their quick fix store for repair.
Jul 05, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
Dec 27, 2008 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
18-55mm lens won't zoom
I fix it!
This problem is due to bad design (I think)
The problem is cause of the guards/holder/stand bends a little the you turn the zoom.
I bend the guards just a little to the left.
This get the guards to stand straight then you "zooming".
Perhaps a little grease can help too, but what kind do you use inside a kamera?
Jul 09, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Nov 04, 2006 | Tamron Zoom Telephoto AF 70-300mm...
Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP AF for Nikon Digital SLR Logo
859 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
