Question about Waring CO1500 1700 Watts Toaster Oven with Convection Cooking
I have a Waring WCO500 with a bad thermostat. Waring tells me that they do not sell parts for this unit. Any ideas?
Waring pro toaster oven: the toaster part spring would not stay down. How to repair?
Most of the time this problem is caused by a build-up of toast crumbs in the latch mechanism. Unplug the toaster oven and follow the instruction manual directions for cleaning the toaster section. Try cycling the toaster lever up and down a few times, then clean out the crumb tray again. If that doesn't solve the problem, you'll have to look for an access to the latch mechanism to clean it out and perhaps gently straighten the latch hook if needed. Note: these are generic directions for all such toasters. I can't be more specific without knowing which model in the Waring Pro line you have.
Jul 02, 2017 | Waring Toaster Ovens
3 of 8 elements are not working. will new ones fix this or should i order other parts just in case?
I would buy a new toaster myself . fixing the old one will not last as long as you hope as the old parts will fail as they will be weak compared to the new wires
Jul 27, 2015 | Waring Wct805b 4 Slot 208v Heavy Duty...
Waring TCO650 toaster oven - how to turn off or down the beeping
I found it! In the manual that came with the toaster (and not the one online), I found the following instructions:
1. To turn the indicator beep OFF: Press both [TOAST] and [BAGEL] keys and hold for 5 seconds.
2. to turn the indicator beep ON: Repeat the above process.
Note - if you lose power or unplug the unit, the beep comes back, so keep these instructions handy. :)
Dec 01, 2012 | Waring Tco650 Professional Toaster Oven
I broke my Euro-Pro PE278 knob and switch (control) for selection cooking mode (midle switch control). Please tell me where can I find this part in Montreal Quebec.
If you don't mind shopping online then try the following address for a list of websites that sell oven parts and maybe one of them can help.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 27, 2011 | Euro-Pro EP278 Bravetti Platinum 1500...
I have a CO1500 and I'm looking for the thermostat assy for it (the contacts are fused together). What is the part # for this assy and do you know where to purchase it?
You may have a problem. I have a CO1500B, and am trying to find parts for it. I have been told that their factory does not sell the parts separately. You can buy trays, rack, rotisserie parts, etc. No repair parts for oven itself though.
Nov 13, 2010 | Waring CO1500 1700 Watts Toaster Oven with...
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Non stop ignitor clicking
The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
Jul 29, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Part P600J smokes when Oster toaster oven is turned on. Where can I get this part.
FIRST UNDERSTAND , there is nothing about this oven thats OSTER except the name oster subcontracts the work out to a china co that makes the oven and put there name on it out of the factory in china it costs $4.00 shipping to the USA $1.00 oster gets them and ships them to wallmart and bills wal mart 24.00 and you buy it and its 36.00 .... its still only a 4.00 oven to oster why would oster ever sell parts for a 4.00 unit ? you think 36.00 is a lot ? in my shop i have a proctor silex toaster made in 1972 that sold for 29.99 in 72. back then that was a lot of money ,if you needed parts you could get them ....... todays appliances cost nothing to make thats why you cant find anyone that sells parts for them . good luck on your diode you would need to know the value to get it , there are no books on this oven ,in this country anyway . i think your stuck
Mar 25, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Overheating
Try CG Industries in Chicago, IL - they rebuild a wide variety of electronic thermostats. Their number is 630-216-5050.
Feb 08, 2008 | Waring CO1500 1700 Watts Toaster Oven with...
Waring CO1500 1700 Watts Toaster Oven with Convection Cooking Logo
154 people viewed this question
Top Waring Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Waring Toaster Oven Expert? Answer questions, earn points and help others
