Question about Kenmore 98702 Stacked Washer/Dryer
The water does not shut off when filling the washer tub in my Kenmore stacked washer/dryer, Model No. 417.93872200. The water keeps rising and overtops the washer tub. What part(s) do I need to replace?
    President:
  • 1,430 Answers
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Oct 13, 2010
On a stacked 417 Kenmore,what is the best way to get to the seal-tub
Here is a service manual for the stacked set. The model may be a little different but the repairs will be the same.
Oct 22, 2012 | Kenmore 98702 Stacked Washer/Dryer
Water wont shut off
Hello, Thank You for using FixYa. I will be helping you today.Unplug the unit if it still fills replace the fill valve. If it stops filling when the porwer is off and keeps filling at start of a cycle it would be the pressure switch or pressure hose came off. The pressure switch is the water level selector switch and the hose goes from it to the tub.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Kenmore 98702 Stacked Washer/Dryer
Washer fills with clean water when off. Water drips from top, behind door hinge from spout.
Your washer is filling up to much. The pressure value switch, the hose that connects to the outer tub.
May 06, 2011 | Kenmore 94812 Top Load Stacked Washer /...
Washing machine never fills. The water keeps flowing and goes right down the drain... So it just stays stuck on the fill cycle... what do I do to fix it?
Have you checked the locatio of the drain hose?
Sounds like the drain hose is lower than the top of the tub and the water is running thru the pump and out the drain hose (water seeking its own level).
Mar 24, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water will not stat in tub
Your drain hose is too low to the ground. Somehow raise to hose up higher.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Leaks at bottom lefthand corner when filling
On that model it's easy to unscrew the front and take it off. You can then see the hoses etc to see where the water is coming from. I had to replace the drain hose on mine.
Aug 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer will not stop filling up it overflows
Very simple. No parts needed! Remove the pressure tube that connects from the water level switch down to th bottom of the tub. Blow out the trash that has accumulated in the bottom of the tub and re connect the tube to the water level switch. Drain the washer. Retry.a097efc.jpg
Dec 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Model # 417.90812990 Stack washer & Dryer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose (behind machine) should be approx 3 feet from ground level when you are re-fitting.
Rate me pl.....if helped.
Nov 16, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
113 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
