Samnsung DLP HLP-5063W Lamp led blinks 8 times. Audio only, no lamp lite. Set shuts down after 8 blinks. Tried new bulb. Still no light
  • dachshock Oct 14, 2010
    Thanks for the suggestion. I have customer willing to let me try their ballast in the other customers tv. Ballast was next attempt after the lamp. I run a small shop. Unable to keep that kind of stock on hand.
  • 10,594 Answers
It sounds problem of ballast supply that is not providing voltage to lamp to produce light.
Replace ballast supply board to solve the problem.
Caution: Ballast board replacement requires expertise and novice should not attempt for that for sofety reasons.
Let me know if you have additional question.
Thanks.
Posted on Oct 13, 2010
My 62hm95 will not come on now had the bulb replace four months ago worked great then nothig the red led stays on and the green one blinks what do i do now???
Some of these sets have a "quick on" feature which runs the lamp all the time and when set is shut off it dims down 60% but does not go off--this can drastically shorten life of lamp.
If you saw the picture at turn on (7 or 8 seconds) you have this feature and it is engaged----that new lamp may be history---I would also look from side/rear to see if lamp fires up even briefly---remove lamp also to make sure not shattered inside.
Oct 24, 2012 | Toshiba 62HM95 62" DLP HDTV
Samsung 50 inch DLP
Most Dlp sets have a fan for cooling the bulb this should start at switch on if it doesnt bulb will not light.
Check fan is pluged in & that blades can turn freely.
Oct 11, 2007 | Samsung (LTR268W) Television
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I have a hlp 4663w that will not turn on checked the bulb it good. three lights blink that it .what is the prob
First. Lamps can look ok in the center and still be bad. Install a new lamp since I do not know when you replaced the lamp or if at all. Turn on the set and at the same time look through the Lamp Door vent slots to see if the lamp Illuminates. If so your lamp is ok and the Color Wheel is bad.
Apr 06, 2010 | Samsung SP46L3HX 46" HDTV-Ready DLP TV
I have the 3 blinking LED lights which form the
Color Wheel, CK all Fans make sure they are running
defective Lamp Fan will shut set down, Pull Lamp out Look inside where Lamp plugs in see if Color Wheel is Turning. Encompass Parts Distrubtion has Parts for this TV 1-800-638-3328 or Just Go to their website.
Mar 23, 2010 | Samsung 56" Slim-Depth LED DLP HDTV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
