Question about Kenmore Elite 45986 Front Load Washer
F2 error - Kenmore Elite 45986 Front Load Washer
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
The "F2" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although a faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...there is also a bellows at the bottom I`ll show you how to check
Posted on Oct 14, 2010
  • Mark MacDonald
    Mark MacDonald Oct 14, 2010
    Sorry, I realize part/MOST of my post was missing. This is a link to essentially the same problem, F2 is the same as F21, just different eras/models of machines.
    Follw the link and you`ll find it should solve your F2 error.
    http://www.fixya.com/support/t6368599-he...
    Good luck.
    Regards,
    Macmarkus.
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
Kenmore F2 Error
The "F2" error code in most cases means runaway temperature.
Jun 28, 2008 | Kenmore 92022 / 92024 / 92025 / 92029...
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Sharp ar-m205 f2 error code blinking instantly and device doesn't go to service menu
hello,
F2 04 Improper cartridge (destination error, life cycle error).
Try to put back the old cartridge , see if F2 dissapears, or try to put in a new one.
the toner cartridge seems to be the problem.
regards,
Adi
Nov 05, 2010 | Sharp AR-M205 Copier
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
F2-04 Error code - How do I clear?
Improper cartridge (destination error,life cycle error)
Dec 02, 2009 | Sharp Office Equipment & Supplies
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
Kenmore Elite 45986 Front Load Washer Logo
532 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
