Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper alarm 5701 blue light stays on when iturn of my truck
SOURCE: How do I lock my keypad
there is a way to do it in the manual which can be found at www.viper.com/support.... i did it by mistake and now can't figure out how to turn it off
Posted on Nov 27, 2009
  • 3 Answers
SOURCE: VIPER 5701 GOES OFF ON ITS OWN
this is a EASY FIX.... if the car has a factory alarm installed, then the installer never connected the OEM disarm wire. its a LIGHT GREEN/BLACK wire connected to the H2 harness. just have them connect that and youre problem will go away .
JOSEPH GARCIA BEST BUY CERT M.E.C.P INSTALLER
Posted on May 25, 2009
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
Posted on Nov 16, 2009
SOURCE: My viper 5701 2way remote works, but gives buzz for all functions
hi did you get this unit from ebay? i am going through the same experience right now and there is a problem with the early units that were manufactured. It will need to be replaced. I am currently trying to get a refund.
Posted on Feb 08, 2010
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
Jan 30, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Parking and cab lights don't flash where arming or disarming. Also Lights don't say illuminated when remote start is on. Did i turn this function off?
It's possible that the parking kight wire is no longer connected or, the (alarm's) fuse for the parking is blown. The parking light fuse for the 5701 is located behind the door on the alarm module.
Jul 20, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 5701 when cold will start with headlights staying on then the engine shuts off and when disarming the alarm the doors wont unlock. when the truck warms up then the system works properly.
This sounds like you may be having a problem with the interface module that is used in your truck and maybe not the remote start. Depending on what kind of truck you have and it sounds like you may have a GM truck... there is an interface that is used to control your locks and bypass the security system in the truck. You maybe having an issue with that.
Jan 07, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm is on a 1996 f150 the alarm will not chirp the led on truck is solid it isnt blinking and it is a 5701 viper
Your alarm got put into valet mode some how
.It's easy to reverse out of it back to normal. First look for a small black push button under the dash somewhere. It's called a valet button. Here are the steps.
1. open door
2.turn key on then off
3.then within 10 seconds hit that valet button once(your alarm light should be off. Tell you arm it again. Then it will blink)
Hope this helps
Aug 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
Jan 14, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I had a viper 5701 responder LE 2 way system installed on my 2006 dodge Dakota, everything works fine but my headlights and parks lights stay on constant while in remote operation and my park lights do...
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Dec 17, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
585 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
