Question about Desa International White Wireless Plug In Door Chime
Doorman reciever WDC813 RX, what are the jumpers for? My bell rings frequently for no reason with a different tone.
3 Suggested Answers
SOURCE: JUMPER SETTINGS FOR SL-6151-RX-A
http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
Posted on Nov 08, 2011
  • 9 Answers
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
Posted on Nov 10, 2011
Will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Jul 17, 2012 | Home Security
Change ring tones on wireless ringer SL-6166-RX-A Door Chime
The chimes have jumper plugs to select the preset songs.
You CANNOT load your own like cell phones allow.
Jul 22, 2010 | Music
May 14, 2010 | Desa International White Wireless Plug In...
My bell rings when my neighbor pushes his button and vice versa how do you correct. Model SL-6166-RX-A purchased at home depot.
Take the back off the 'bell' and you will see two rows of gold colored pins running parallel to each other, eight pairs I think. Three of these pairs of pins will be covered by jumpers. Jumpers connect two pins together.
Pull any one of these jumpers off it's pins and move it to any other pair of pins.
Make note of which jumper (the pins are numbered) you moved and to which pins you moved it.
Now, take the cover off the 'button'. You will see an identical set of jumpers and pins to those in the 'bell'. Duplicate there, the change you made to the 'bells' jumpers.
Ghost rings solved!
Ok, ok, on the wild outside chance that the problem persists, just move another set of pins.
Remember, the jumper configuration in the 'bell' and 'button' ' must be identical.
Nov 04, 2009 | Desa International White Wireless Plug In...
Dings sometimes with out pushing the button ??
I believe there are either dip switches (or old-fashioned "jumpers" in both the button (the 'transmitter') and the dinger (the receiver). See if this is the case, and that the dip switches (or jumpers) are in the same position in both units. Then, simply switch one of the dip switches (or jumpers) to another 'position' in both the button and the dinger. There ya go...
Mar 05, 2009 | Desa International White Wireless Plug In...
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
Jan 19, 2009 | Desa International White Wireless Plug In...
Doorbell/cartel
The cadence is different, but you can change all the other rings to a different tone. On a 76xx phone, press PROG and the CO button twice. Press your navigator button up (or down) until you hear the tone you like, then press enter to save.
Tones 01,04 and 05 tend to be reasonable.
Carl
Aug 01, 2008 | Panasonic KX-T7633 Corded Phone
Pixma mx 310 fax auto
enter rx settings and select teleline as fax priority.
Mar 30, 2008 | Canon FAX-JX200
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Desa International White Wireless Plug In Door Chime Logo
318 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
