Question about Tag Heuer Watches
User Manual for a Tag Heuer Model WG5111-PO? I don't know which way to turn the crown to manually wind the watch in position 1? I know it is 12 years old - still works.
  • 8,197 Answers
On links below are the only manuals that tag heuer have.
http://ww2.tagheuer.com/_documents/manuals/ei2246_en.pdf
http://ww2.tagheuer.com/_documents/manuals/EI2241_en.pdf
http://ww2.tagheuer.com/_documents/manuals/EI2250_en.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 13, 2010
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    How do I wind up my tag carrera automatic using the crown??
    Wow, how wrong yall are.
    There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
    Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
    The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
    Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
    I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
    If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
    Clcik on "user manual" to download the manual for your watch.
    There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
    How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
    Feb 01, 2011 | Tag Heuer Formula One
    My alarm does not sound on my Tag Heuer Kirium F1?
    Have you a copy of the manual?
    If you have, then you will see that it can be turned off (last page), is this likely to be the case?
    If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
    This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
    If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
    If not look at a similar watch for a generic manual.
    Jan 27, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
    New Tag Aquareacer Automatic wont manualy wind
    If thats a new watch then there could be an issue in the movement and its possible it could be covered under warranty. Take it back to the store asap!
    Jan 15, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
    How can i make the date of my tag heuer formula 1 change automaticaly?
    To s e t t h e t i m e a n d d a t e
    Your TAG Heuer chronograph is fitted
    with a screw-in crown and safety seals
    which guarantee it to be waterproof
    to 200 m (660 ft).
    Position 0: Crown is screwed in
    (normal position).
    Important: The crown must be
    screwed in correctly to guarantee
    the water-resistance of the watch.
    Position 1: Crown unscrewed.
    To change the hour (change of time
    zone) or date quickly, unscrew the
    crown, pull it out to position 2 (quick
    corrector) and turn it in either
    direction. This mode allows you to
    change the hour and the date without
    any loss of minutes.
    The date changes each time the
    hour-hand passes midnight.
    To set the time, unscrew the crown,
    pull it out to position 3 (setting the
    time) and turn it in either direction.
    After setting the date or the
    time, push the crown back and
    screw in to position 0.
    Oct 10, 2009 | Tag Heuer Formula One
    Hi there i have bought a second hand tag heuer carrera tachymeter,i dont have a user manual,but cant seem to get the chronograph functions to work ?
    Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
    If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
    I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
    Thanks!
    Sep 20, 2009 | Tag Heuer Carrera Series Chronograph Watch
    Tag heuer automatic series, how do you start the watch after purchasing?
    push the crown in if it is in the adjust position .then shake the watch around the auto mechanism sould start the watch
    Aug 23, 2009 | Tag Heuer Automatic Chronograph Series...
    Dont know how many time to wind it
    until it begins to feel just slightly taunt,Do NOT over wind a wind-up wrist watch, if its a self winding you should just have to walk in it to wind it. here is a link to a pdf of your manual which has winding procedures, Good luck Jon click here
    May 21, 2009 | Tag Heuer Aquaracer Chrono Automatic...
    Just Got a tag professional ( Previously Owned)
    Hard to tell without knowing what model or caliber number (usually on back). Generally, if you pull the crown (winding knob) out all the way you can set the time. Push it ONE click in, you can set the date. Check with the manufacturers website for a book of instructions you can download.
    Jun 24, 2007 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
    Open Questions:
    Watches Logo
    1,608 people viewed this question
    Top Tag Heuer Watches Experts
    Jimmy Accardi
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
