Question about HP Compaq Presario V6000T Notebook
Compaq Presario 6000 Monitor Problem
I have a Compaq Presario V6000 laptop, and as of yesterday, there is a narrow white horizontal line 40% down from the top of the monitor. Otherwise the laptop work great. This is running Windows XP professional. This occured once before about a year ago, but a restart fixed it. NOT so this time.
Any advice?
  • Hdupuis Jun 08, 2008
    Thanks for the feedback. I was hoping for better news but this is what I expected. Saved me some time!
    Thanks again.
    Genius:
  • 3,587 Answers
Sounds like your lcd screen is on it's last legs...time for a replacement..
Posted on Jun 01, 2008
How to overcome white screen of death
Blue screen of death. (BSD)
Windows operating problem.
White screen means you do not have a video signal.
Problem is;
A) Graphics Chipset
B) Video Cable
C) LCD screen
1) Graphics Chipset:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The graphics chipset, or graphics I.C., is properly called the G.P.U.
Graphics Processing Unit.
The GPU, just like a Processor, is mounted to a small printed circuit board, which is the interface used to connect the GPU, to the motherboard.
http://www.ebay.com/itm/NEW-Original-nVIDIA-Geforce-NF-G6150-N-A2-BGA-ic-chip-north-bridge-Chipset-/271010886762?pt=LH_DefaultDomain_0&hash=item3f1981f46a
[ Top View.
The black rectangle with Nvidia NF-06150-N-A2, is the GPU. The greenish square around it, is the Printed Circuit Board. PCB. The little white rectangles with the silver looking band, in the middle of them, are ceramic capacitors ]
The above is the GPU for the HP Compaq Presario V6000 series, of Notebook PC's.
The Compaq Presario V6000 series of Notebook PC's, has a graphics chipset overheating problem.
Also affects the HP Pavilion v2000, Pavilion v6000, and Pavilion v9000, series of Notebook PC's.
The cooling components for the v6000 series, is a Cooling Tube, Heatsink, and Fan Assembly.
Top view;
http://www.ebay.com/itm/Compaq-Presario-F700-CPU-Genuine-Laptop-Heatsink-Fan-449961-001-TESTED-/251119771623?pt=US_CPU_Fans_Heatsinks&hash=item3a77e79fe7
Fan Assembly (Black) to the right. Fan inside a 'D-shape' shroud.
At the top is the black rectangular finned -> Heatsink.
The slightly flattened copper tube is the -> Cooling Tube. It is sealed on both ends, and filled with Nitrogen.
The first little aluminum looking tab, away from the Fan Assembly, and on the Cooling Tube, sits on the GPU.
It is TOO small in surface area. The reason the GPU overheats.
The next small metal plate that is X-shaped, with four mounting screws, sits on the Processor.
Bottom view;
Put your mouse in the middle of the photo, then move around to enlarge.
Fan Assembly (Black) to the right, come to the top left corner of it.
To the left of the top corner, and mounted to the Cooling Tube, is a copper rectangular plate.
This small rectangular copper metal plate, sits on the top of the GPU.
Coming further to the left of that small copper plate, is the one that sits on the top of the Processor. Has an X shape with 4 screws in it, on the outside.
Inside the black rectangle is the small copper plate, which sits on the Processor
There is some grayish Thermal Paste that has been leftover.
Heat is absorbed by the two small metal plates, sitting on the Processor, and GPU.
The heat is then absorbed by the Cooling Tube.
The Cooling Tube transfers the heat to the Heatsink. The Heatsink absorbs the heat in the middle of it, and radiates the heat away from it by the tall, thin fins.
The Fan Assembly helps carry heat away from the Heatsink's fins.
With constant repeated overheating, the mounting for the graphics chipset to the motherboard, develops a bad contact. bad contact of graphics chipset to motherboard.
The graphics chipset is mounted to the motherboard, with a BGA surface mount. Ball Grid Array.
To explain the BGA surface mount compare to an older Intel Pentium 4 processor, that uses a Socket 478 processor socket.
The bottom of the Processor has contact pins. 478 of 'em.
The processor socket has matching socket holes,
http://en.wikipedia.org/wiki/Socket_478
With a BGA surface mount there are no contact ->pins, nor socket holes.
In place of the contact pins are Solder Balls.
In place of the socket holes are Copper Pads.
(Gold plated also)
The graphics chipset is set onto the motherboard, with the Solder Balls lining up on the Copper Pads.
Heat is then applied at a specific temperature, and length of time.
This solders the graphics chipset to the Copper Pads.
Which in turn solders the graphics chipset to the motherboard.
Constant repeated overheating causes the solder joints, (solder connections), to partially melt.
Then when the laptop is turned off the solder joints re-harden.
This causes Cold solder joints, and makes a bad contact of graphics chipset to motherboard.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the laptop.
Connect to the VGA port on the left rear.
You can use a CRT type of monitor, (Looks like small TV), or a flat LCD screen monitor if it has a VGA cable.
Example of a VGA cable, and VGA connector, (VGA port on laptop),
http://en.wikipedia.org/wiki/VGA_cable
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on. By factory default the display should be on the external VGA monitor.
If Not;
there are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press the Fn key down, and hold it down. Tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F4 key.
Still no?
You have problems with the mounting of your graphics chipset, to the motherboard.
If it is that you Do have a display on the motherboard, then the problem is the video cable, or screen Inverter, or LCD screen.
Post in a Comment if you get a display on the external VGA monitor, and we will go from there.
This is one tech's method to fix the problem. Not repair, FIX.
(Not advertising for this guy, just for reference of method )
http://www.youtube.com/watch?v=JEpnqhRYGLw
5 minute video showing a BGA Rework Station. Helps to understand what a chipset looks like that uses a BGA surface mount, and the BGA surface mount process itself,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll the page down, click on the red -
Take a few minutes to view the IR 650 demo video
HP Compaq Presario v6000 series of Notebook PC's -
Service Manual (Free from HP Support),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3177516&
Scroll the page down, click on -
Compaq Presario V6000 series of Notebook PC -
Maintenance and Service Guide
Regards,
joecoolvette
Aug 05, 2012 | HP Compaq Presario V6000 Motherboard -...
Black screen with flashing horizontal lines
it can be the fibre or someone pressed the screen on the topside or plced something heavy on it
Apr 14, 2017 | Compaq Presario C700 Series Laptop...
Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
Oct 01, 2009 | Dell Inspiron 9100 Notebook
Compaq Presario V6000 screen goes blank after Windows Welcome
1st it could be virus or it could be monitors bad how to find need to hook it to out side monitor and test then get back to me lala linda
Jun 15, 2009 | Compaq Presario Notebook
How to activate mute button in laptop compaq presario V6000
goto google enter "compact presario drivers" click on link to HP Support and drivers. once there, enter your product name/number. it should show you a list of all drivers available for your model. download your audio driver and reload it to your laptop. sometimes drivers get currupt and dont work right. hope this helps...good luck
Mar 18, 2009 | Compaq 220W Power Supply for Presario...
Compaq presario r3000 laptop monitor problem
You have a bad LCD area on the monitor. You can replace it yourself or take it to a repair shop.
Mar 16, 2009 | Compaq Presario R3000 Notebook
Try fn key, And LCD/TV Or LCD/VGA usually marked on 1 of The number ( Numerical ) Or F Keys.
Remember to switch back before closing down, Otherwise the laptop will try to look for the projector.
The other option is to see, which device is set to boot first from the systems Bios.
Mike @ compurepair.
Sep 22, 2008 | Compaq Presario 700 470024-192 Notebook
Need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
Jul 31, 2008 | HP Compaq Presario V6000T Notebook
How to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Jul 08, 2008 | Computers & Internet
HP Compaq Presario V6000T Notebook Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
