Question about Amana ALE331RAW Gas Dryer
How do you adjust a slipping belt for an Amana # ale331raw? Thanks
  • Amana Master
  • 8,220 Answers
The belt ribs go against the drum. This link shows various configurations BELT CONFIG.
Your dryer tech service manaual: AMANA DRYER
Posted on Oct 13, 2010
My Amana dryer gets clothes stuck between the drum. how do i fix this
Sounds like the drum bearings are worn out. this leaves a gap for the clothers to stick into. You will need to replace them. Check the support rollers also when you have it apart.
Sep 01, 2009 | Amana ALE331RAW Gas Dryer
Amana dryer does not run but i can hear the motor faintly
Sounds like the belt is either broken or slipped off the pulley. Remove the back of the dryer and find the motor. Look to see if the belt is still attached to the pulley. If not, look to see if it has slipped form the pulley and is hanging from the drum, or if it is broken. More than likely, regardless of which it is, you will just need to replace the belt.
Jun 03, 2009 | Amana ALE331RAW Gas Dryer
Amana dryer Model leb107w2
It sounds like it needs a new belt. The smell is probably the rubber belt overheating because it's slipping. The belt tensioner may need adjusting or replacing as well.
Apr 21, 2009 | Dryers
Thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Nov 25, 2008 | Amana ALE331RAW Gas Dryer
Start cycle does not respond
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 26, 2007 | Amana ALE331RAW Gas Dryer
Amana gas dryer
You have to take the front off on that model.. to get at the inside.. heres a diagram that may help ya out http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1268&modelDesc=AMANA%20LAUNDRY&modelNumber=ALE331RAW&documentID=M0411885&documentTypeID=PLDM&documentClassCode=PV&titleType=DOOR%2C%20FRONT%2C%20ACCESS%20AND%20TOP%20PANELS&titleID=00002&
Oct 10, 2007 | Amana ALE331RAW Gas Dryer
Amana dryer belt
You will probably have to open it up from the top and/or back. If the belt looks alright (it probably won't, though), check the belt tensioner. Carefully observe how the belt goes on and around the tensioner before replacing.
Oct 06, 2007 | Dryers
Amana ALE331RAW Gas Dryer Logo
199 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
