Question about Konica Minolta Minolta DI1811P Digital printer, copier, fax, scanner, up to 18 pages per minute, Maximum paper cap...
I am getting an error message ( set plug in counter) how do i fix the problem
How do i fix error bk-crum error 093-925 - using geniue carttidges
If you have just installed these cartridges and got this message immediately, Make sure that these are the correct cartridges.
The cartridges for the Xerox 6180 are identical to look at, but have different part numbers, and crucially different chips.
There are also pagepack/Eclick versions of these cartridges.
If your printer is a 'pagepack' version of the printer, it needs pagepack/Eclick cartridges, and will give an error if normal cartridges are used. Similarly, if your printer is a 'normal' version, and you put a 'apgepack/Eclick' cartridge in it, you'll get an error.
If you've had the cartridges in the printer and used it WITHOUT getting the CRUM error message, the counter chip has become corrupted. This can happen if there is a power problem during a chip 'write' operation.
The error message points to the Black cartridge.
Sep 22, 2014 | Xerox Genuine Phase 6280n 6280 6280dn...
How do I "insert plug-in counter"? What could be causing this message? It popped up after fixing a paper jam.
the plug in counter is an add on accessory, please check that you have not changed any settings on the machine.
Nov 04, 2013 | Minolta DiALTA Di183 Copier
Sharp FO-4470: Error message is: "check cover or drum"
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Apr 23, 2010 | Sharp AR-F152 Fax
We have a Sharp AR 207 and are getting an error message of U 2. How do we fix it. Do not have a manual.
U2
Content EEPROM serial communication
error
Detail-
Error in communication with
EEPROM
Cause
EEPROM failure
Installation of uninitialized EEPROM
MCU PWB EERPOM access
circuit failure
Check and
remedy-
Check that the EEPROM is
properly set.
To prevent against loss of
counter/adjustment values, record
the values with simulation.
U2 trouble cancel with SIM 16
MCU PWB replacement
Mar 05, 2010 | Sharp Office Equipment & Supplies
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
Printer not printing. Error message reads see your documentation may need service
Counter reach its preconfigured limit it is just, you have to reset the counter back to zero count. This feature could be attributed not to overflow the waste bin.
In your web browser search bar, key in " epson reset software" the uppermost link is the one. Read the tutorial before doing so.
Hope you get it easily.
May 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
E3 error message
Dude,
E3 refers to Paper Jam :)
this may come in handy:
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
îäíàêî, äëÿ ôóíêöèé 4 è äàëåå åñòü ïðèìå÷àíèå : òîëüêî äëÿ àçèè.
à âîò â îïèñàíèè ôóíêöèè 3 åñòü : Reset except for the
followings:
- USB serial number
- Destination setting
- Waste ink counter ...
Turn it upside down and than check.....same error code or diff.
Any help, can buzz me nytime ...
Thnks.
Jan 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp730 Error message
Dear sir,
physically you can't replace that part ,its a EPROM counter, which shows you the error message .you can only reset the counter through that procedure.otherwise if you want to replace that part then you have to contact authorised Service centre , to replace that part.
Regards
Dec 17, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Need to reset purge counter due to error 46
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Mar 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Konica Minolta Minolta DI1811P Digital printer, copier, fax, scanner, up to 18 pages per minute, Maximum paper cap... Logo
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
