Question about Mitsubishi WT-42311 42" Rear Projection Television
Need the fuse number for my mitsubishi tv model wt-42311. Hte fuse is located in the back next to the power cord for the power source.
  • 1,476 Answers
Mainitpa2,
The voltage and current rating for the fuse should be marked on the circuit board directly below it or very near to it. The majority of fuses in TVs these days are GMA type. If your unit blew a fuse chances are that a new one will also blow at turn on if no troubleshooting was done to find a short. It will not harm the unit to try a new, correctly sized fuse, but don't be surprised if it blows immediately. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you with the troubleshooting process.
Thanks for using FixYa and for a great rating.
hardrocko
Posted on Oct 13, 2010
Mitsubishi WT-42311. Green tinted screen, now won't stay on.
Yes,the 2 STK convergence ICS and some or all the resistors,the pico fuse are dead.U know soldering,have the soldering tools,and solders right?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts,and labors.
May 13, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 green light flashes and turns
Mits are bad about power supply capacitors failing. It can be fixed fairly cheaply, but requires some skill at disassembly of the tv and unsoldering/soldering.
Dec 10, 2009 | Televison & Video
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi model # wt-4609 .. won't come on... error code blinks two times pauses then two more
This is error code for short protection--95% of the time in this model it means one of the soldered in fuses that protect the convergence circuit is blown.
Both convergence chips and the blown fuse or fuses need to be located and replaced----if you give me the full correct model number I will tell you which parts it uses.
Some people are able to do this repair themselves--depending on model number you would begin by unplugging the set and testing the fuses for the convergence circuit--if either or both are bad the chips for the convergence circuit got them--just changing the fuse will do no good--and can do more harm.
Let me know model number ---wt- and 5 numbers usually
if this helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WT-42311 DLP Bulb Replacement
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Jan 14, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
and or the
convergence IC's (STK392-110) had failed and caused a diode (D522) to short
out.
If Q5A00 check bad there are other parts that have to be checked or
replaced.
Dec 02, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 hd tv has "pulsating" problem
A Mits qualified tech and/or warranty repair facility near you should be consulted.Involve Mits in the repair loop for accurate info.
Sep 26, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
