Question about Panasonic KX TGA400B Cordless Expansion Handset
PHONE WONT HOLD CHARGE - BATTERY NOT THE PROBLEM
Why wont my samsung trend cell phone charge
Sounds like a battery problem. If the battery is weak, it won't charge, or will not hold charge for a long time than desires. Replace the battery, and check. Before replacing the battery, check the voltage of the output to your phone charger. If there is no DC output, the battery won't charge.
Gopakumar Gopalan Google
May 16, 2014 | Samsung Galaxy Trend Lite GT-S7392L DUOS -...
My cell phone wont hold a charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 28, 2011 | Sprint LG Rumor Touch Phone cover by...
What does it mean when your phone wont charge or hold a charge.?
my dad had that problem when it wont charge my dad had to buy a new phone the charger might be broke or its just a bad for holding battery life sorry go to the store and ask the phone person what cell phones have the lonest battery life bring the charger so you can show them
Dec 23, 2011 | AT&T Cell Phones
Phone randomly turns off Wont hold a charge with a new battery, wont charge when connected to charger
Theres a possibility that the IC on your phones motherboard was damaged. if you already tried known good battery and charger and still wont get any charge then your phone motherboard is alread damage and needs replacement or you can buy a standalone charger for your battery.
hope this help
Sep 03, 2010 | Cell Phones
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
My phone wont hold a charge
Battery is done. Won't hold charge. Get a new battery at Fry's or elsewhere if your phone isn't ancient and you love it. Try to find a lithium-ion. I used to buy replacement batteries from Belkin on my older phones and they were quite good. If your phone is ancient, can't find battery or phone is just outdated get a new phone from your carrier. From free with new contract all the way to a few-hundred dollars for a smart phone. You may even have an upgrade discount waiting with your carrier. You'll find something in between that suits you.
Jan 30, 2010 | Motorola Mobility i730 Cellular Phone
My envy phone wont hold a charge
if the battery has got wet then it can be damaged usually there is a white dot on or near the battery if it is red its damaged or the battery has lost it power to hold a charge from normal use a new battery would solve the problem hope this was helpful:)
Nov 16, 2009 | LG enV VX9900 Cellular Phone
My philips cordless phone wont charge with new batteries
try the old battery if you still have it then see if it holds a slight bit more once charged.If it does then go back to the seller of the new battery for a replacement.
Aug 31, 2009 | Philips SINGLE HANDSET USB VOIP PHONE
My new phone wont hold a charge. Is this common
maby battery are damaged insite buy new battery or let store check battery maby waranty
normaly not on batterys
Aug 24, 2009 | Motorola Mobility MOTOROKR EM330 Cell...
Phone wont hold a charg and wont turn on
what you have to do is to clean your phone using isoprophyl alcohol i mean you clean the main mother board then you dry it using hair dryer ,after all that try to replace the battery it has reach it death neal the cells inside they are no longer able to hold the charge.advice by dogy.
Jan 04, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Panasonic KX TGA400B Cordless Expansion Handset Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
