Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
THE TIMER DOES NOT WORK , NEED TO REPLACE IT WHERE IS THE PART LIST FOR ML600TW MALIBU ANTS GOT INTO THE DIAL TRY TO CLEAN IT OUT APPENRENTLY BURN UP THE MOTOR IN THE TIMER LIGHTS OR ON ALL THE TIME.WORKS MANUAL ONLY.
Try this if your timer motor fails........
My timer motor failed on two units; would be $500 to replace both transformers.
I did the following with great success for less than $30 each:
You can always just remove all the pins from the failed timer and set the unit to on. Then plug the whole transformer into a heavy duty outside timer. Outside timers range from $25 to $60 and are available as digital units with more flexibility; and no moving parts. The timer I found adjusts automatically for sunset and then the off time I choose.
Here is the model timer I have:
Intermatic HB880R 15-Amp Seven Day Outdoor Timer
Posted on Nov 28, 2015
I've done a lot of reading and research on Malibu
No replacement parts for Power pack, or schematic >> Malibulights.com shows replacement lights and replacement power packs
Manual for Malibu 600 Watt power pack
SAVE the pins off old power pack and see if they match pins on new power pack ... because you can't find pins on the internet
When the power pack goes bad or you lose the pins, then you buy another power pack
Things to remember:
Match number of lights to power pack wattage
30 - 20 Watt bulbs => 30 x 20 = 600 Watt power pack
Replace bulbs as soon as they burn out, or other bulbs will burn out quickly, and I think it causes power pack to burn out sooner too.
Up-vote if this helped. Thanks for the feedback.
Posted on Oct 14, 2010
  • Anonymous May 22, 2011
    You cannot repair power pack once it stops working. For more information:http://waterheatertimer.org/Malibu-power...
How to I set timer for ML600TW
Intermatic/Malibu ML600 power pack has analog timer dial located on top of unit that makes one revolution per 24-hour day, and a rotating-round override switch located above the analog dial.
Copy following link for how to set analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
Also copy following link for advisories, tips, and warranty information to save money and get power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 03, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
My ml600tw timer is not working. The unit has power, but the timer will not turn.
If the clock dial is not rotating, the clock motor has gone bad.
Easiest solution is set power pack in override so lights are on, then plug power pack into cheap plug-in timer.
Some people report being able to disassemble clock motor and add vaseline to gears to restore functionality. Other peole report not remembering how all the tiny gears fit back together.
My experience is that once motors slow down and overheat, they never work correctly again.
There are no replacement clock motors for power packs.
Open following link for power pack troubleshoot and resources and tips:
Jul 10, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
The transformer will work if I manually turn the dial. The dial will not automatically turn anymore.
If the bulbs turn on when you manually rotate dial, then the power pack has electricity.
A lot of people ask for replacement Malibu tripper pins on Fixya, and it sounds like your trippers are working fine.
If clock has stopped rotating, that means the power pack has malfunctioned, and needs to be replaced.
I did find some tips to help folks preserve their power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 11, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Need red plastic timer clips for my ML600TW. Transformer works, but only have one red movable clip for setting a time. Timer may be broken, but would like to try installing the on/off clips first. Any idea...
Open following link for ML power pack trippers, plus troubleshoot, plus tips to keep power pack from burning out, and warranty:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 04, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
My ml600tw will not turn itself on when the pin gets to the pre-set time
Open following link for ML power pack troubleshoot, plus tips to keep power pack from burning out, trippers and warranty:
Upvote the help.
Sep 02, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Have Malibu low voltage transformer. Need red and
Routinely vailable on eBay...sometimes listed as "Intermatic" (Malibu's parent company.).
Nov 22, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu landscape transformer
If it is keeping time try moving the stops. If it is not keeping time the motor is probably burned out. These transformers don't have a lot of serviceable parts to them.
Oct 29, 2008 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
451 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
