Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
  • 7,733 Answers
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Posted on Oct 13, 2010
Poulan chain saw wild thing will not start
simple things first
right fuel /oil ratio in tank ?
aircleaner not blocked off with sawdust?
stop switch set to correct "run" position , switch not broken damaged ? chain brake set ?
choke set correct to start ?
primer bulb working correctly , fuel is visible inside bulb
Apr 30, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need to have a manual on this wild thing so that i know the right ratios for the gas.
This Chain Saw requires a 40:1 gasoline to oil mixture. This is typical for all 2-cycle motors. More information can be found here:
http://www.ehow.com/how_4464807_fuel-poulan-wild-thing-chain.html
Aug 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
No problem i want to know how big the motor is in cc's
40 CC's or 2.5 Cubic inches
Poulan, Wild Thing, 2375, 18" Gas Chain Saw, 2.5 CUIN, 40CC, 2 Cycle Engine, Vertical Cylinder Design, Dual Counterweight Crankshaft, Primer Bulb, Inertia Chain Brake, SuperClean Air Filtration System, Gear-Driven Automatic Chain Oiler, Full-Wrap Handle
Mar 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing chain saw rope came off
by the time it would take to tellyou ,you would be better to take it to any small engine work shop. it is not difficult but it is to explain
Jul 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing will not start
check the fuiel filter in the gas tank, it might be dirty, or need to be replaced
Jan 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Insufficient chain oiling
Sorry to tell you this but you need a new OIL PUMP but it's not a difficult thing to replace.
On the main shaft of the crank shaft under the centrifugal clutch is a spiral wound wire that matches a plastic part that is the oil pump. You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time.
Glad to be of assistance.
Oct 09, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
351 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
