Question about Sony 12" Single-Voice-Coil 4-Ohm Subwoofer
Distortion from an unboxed 12''
I bought a sony 12'' 1000W unboxed but itched to test it, so i hooked it up to my 350W amp only to hear distortion almost like a ratling coming from the sony hexagonal emblem in the middle of the speaker...? is this sound because its unboxed or because it might be broken?
    Problem Solver:
  • 8 Answers
Hook the leads up to a wire connected to a 120v wall outlet and the problem wont bother you any more.
Posted on Nov 27, 2008
I have 2 sony xplod 4ohm subs rated 350w rms and 1200w max, i have them in really shallow boxes because i drive a single cab toyota, i know these subs **** but i do also know that they can hit alot harder...
the premier amp is better since it has a better rms rating (360w total or 160w each sub) than the eclipse (280w if you bridge all 4 channels which isn't possible but 140w for each speaker bridging 2 channels per speaker). Neither are going to push your subs but if you get another amp wiring kit and use one amp per sub they will sound a lot better and you could just hook both power wire and ground wires from the bridged channels to the power and ground terminals for the sub. That would be my suggestion since the subs are rated at 350w and each amp is 280w and 320w which will push but not blow the subs.
Aug 17, 2010 | Sony Car Audio & Video
What is wrong with my 1000w sony xplod amp?
need repairs on the inside usually when u see that fuse melt something else probably melted on the inside. something is grounding out the amp on the inside . get it checked
Jun 05, 2010 | Car Audio & Video
I have a 1000w amp but it got burned why??
I'm sorry but your problem was a little confusing. Your speakers worked fine, you hooked up a 1000W amp and now you cant hear the sound ?
Then you say "they say because the wires were connected wrong in the amp it burned" does that mean your amp burnt out ?
Please post back and sort these facts out for further assistance.
As of right now im not sure if the problem is with the speakers or the amp itself.
Oct 01, 2009 | Alpine MRD-M1005 Car Audio Amplifier
Will this give me 400 watts on each
bignatedabal: You can't get something more out of a device than it's rating. In other words, if you have a 400W amp that's all it's going to produce. For example if you're looking to drive both sub spkrs @ 350W each then buy a sub amp with a rating of 700W @ 2ohms & connect your 4ohm spkrs in parallel to the amp. Each spkr will produce 350W of sound if everything is installed correctly.
1 thing to look for in amp mfg's. Look for those who rate their amps in RMS power. This is the true output rating. Many amps are rated in peak-to-peak which seems great but doesn't tell you the real story, unless you know how to do the math to determine the RMS. The better mfg's will take the time to test their amps & rate them properly. Also look for massive heatsinking (the cooling fins). I consider cooling fans to be a benefit as well.
If you have addtional questions, drop me a line.
peace-out
Jan 18, 2009 | Kicker ZX400.1 Car Audio Amplifier
Problem with amp?
Give that new sub a chance to "break in". New speakers require a few hours of use before the voice coil(s) and spider break in and began operating at their best performance. Is the box within the operating specs of the sub? Is this a ported box; if so you will here some turbulance type noise from the port. What type of distortion are you hearing? Alternator noise(dentist drill like sound) would only be noticable through a sub at lower volumes due to the frequency response of a sub. Is the amps lowpass crossover turned on?
Mar 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Distorted Bass
Check the specs on the required ohms for the speakers. If it calls for 8 ohms and your speaker is 4, then you are pulling twice the normal current and this has blown an output transistor.
Mar 02, 2008 | Legacy Audio LA1030 Car Audio Amplifier
Sony Xplod 500w green power light no sound
try running the system with a cross-over configuration.
So your left + will be left + and your right + will be in the right + but put the right (-) where the left (-) is and left (-) where the right (-) is. If that doesnt work, then that means that you shorted out your audio out channels. the only way you can fix that is if you have good soldering skills. But other than that I'de say scrap it, unless you have the high outputs and then buy another amp, some mids and highs and connect the mids and highs to the xplod
Feb 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
1000 watt amp sony xplod
That's not a 1000w amp. It's a 400 watt amp when loaded to it's lowest rated load. If you have one speaker per channel (the only safe load if you have single 4 ohm coil speakers), you're only getting 165 watts/speaker. It's probably distorted because you're driving it to clipping.
Jan 01, 2008 | Car Audio & Video
Sony 12" Single-Voice-Coil 4-Ohm Subwoofer Logo
112 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
