Question about Dell Dimension 9100 PC Desktop
I don't have sound coming out of my computer. I've checked the wiring, volume controls, and speakers and they all check out okay. My computer is a Dell Dimension 9100. Help!! barbara4818@verizon.net
  • Dell Master
  • 1,183 Answers
if you are not getting no sound, from the computer and you have checked all the hardware settings. The problem could be that you are missing drivers for windows sound devices . You can try downloading and installing the drivers from the following link
http://tinyurl.com/269ymxy
Thanks for using Fixya
Proton
Posted on Oct 13, 2010
We have older speakers that came with our computer, and we just moved and since we've moved no sound has come out of the speakers. i have checked a million times and everything's plugged in. i...
First check if the driver for your speakers is up to date. For all we know maibe something that was installed automaticaly or by some one might be interfearing with them. Go to the Window menu, click on Conrol Panel, click on speaker settings, and check to see if anything looks off (like everything is gray and you can't really select anything). If everything seems ok check all the volume settings. Remember there are 3 things that control the volume on the speakers. 1: the nob on the speakers; 2: the volume on your desktop (lower right side next to the clock); 3: the volume on the program you are using (like windows media player). Another thing to remember is some computers come with a mute button (ether on the keyboard or monitor. If your computer has a play/skip/stop buttons it most likely has a mute button. Oh, and some computers have a volume nob next to the CD/DVD player (where you put in disks). Maibe some one turned it down as they grabed to move it. Make sure it's also turned up. If they're all turned up then most likely something got bumped loose during the move. In wich case you'll have to open it up and check the conections. It'd be a good idea to test some one elses speakers so you'll know if it's the computer or the speakers...or you could try pluging in the speakers you have into something else (like an MP3 Player).
Sep 19, 2011 | HP JBL Platinum Computer Speakers
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
I have an HP Pavilion 6000dv...specifically, it's a 6119us. I have no sound at all. I've checked the device manager, nothing is muted, I've gone through the troubleshooting program...still...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 28, 2011 | Computers & Internet
I cant get sound from my Logitech speaker system.I've checked everything.I don't know why it's not working,but in the control panel it says "There is no system on"
also
hope this helps
May 08, 2011 | Logitech S120 2 Speakers
When I plugged them up the light on the speakers did not come on and no sound
also
hope this helps
don
Feb 25, 2011 | Dell A215 Computer Speakers
Sound comes out of one speaker
Check the wiring connections. Replace any speaker cable.
Sep 25, 2017 | Kinyo PS-205 Computer Speakers
Left speaker is not working on my 2.1 speaker system...
A few things can cause this to happen. First we should check the computer. Take a pair of headphones or other speak set and check if sound comes from both sides. If to then the computer output is correct, else the computer is channeled to output to one side.
To change sound settings, if this is windows, go to your control panel and look for sounds option. In there you can change speaker settings, change volumes. On the volume control you can balance the speaker output. center the slider to make both correct.
If sound is coming from the PC correctly with a test object you will need to check your speakers for a fade option, not many have this it is just a suggestion. If no fade option exists, make sure the plug is totally seated. Improperly seated plugs will cause only 1 channel to be outputted or none.
If all the above does not help then check the cabled leading form the computer to speakers for damage as well as checking the wire between the left and right speakers for damage. Many times the output lead from the right to he left gets damaged from stress or other things and will stop output. Wiggle and pull the wire gently in each direction if they don't physically look damaged to see if sound is produced. if it is then the wire is internally damaged or loose from the speaker.
good luck
Mar 14, 2010 | Altec Lansing Audio Players & Recorders
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
No sound
What exactly is evrything?
Reinstalled sound drivers?
Checked your speaker cord to make sure it comes into the green hole on the back?
made sure your speaker wires are not broken?
Volum on the speakers?
Control pannel> Sound> Speaker Icon: Are the controls HIGHLIGHTED? If not sound driver is not loaded.
Check Volum MUTE. SOme programs MUTE your volume without a warning.
Jan 04, 2008 | Behringer FCA202 - FireWire Audio...
Dell Dimension 9100 PC Desktop Logo
93 people viewed this question
Alun Cox
