Question about Car Audio & Video
Infiniti G 35 coupe 2003 Radio makes a loud noise when the car is first started in the morning, and it doesn't matter wheather the radio is on or off. It goes away in a few minutes. The CD does not work it will not accept a disk.
  • Tex9 Oct 13, 2010
    I will check this out.
    Thanks
    President:
  • 2,047 Answers
Usually CD players in cars dont give trouble or problems. Although when they do the solution is usually staring us in the face. If the CD player does not accept discs into the unit it is as a result of an existing CD inside the unit. Often times maybe due to mistake or otherwise freak incidents the disc which is put inside a player ends up leaving the disc tray and causes such problems in the system.
The noise which is heard is as a result of the disc tray moving around and having contact with the disc and this causes the noise.
On the other hand it could be the mechanism which helps the unit to rotate the disc which has an external object in between it.
The noise stops after a few minutes because whenever the car is put on initially the disc lens moves around and in the process makes contact with the disc inside the unit.
Best solution for this is to send the car to a car radio shack and get them to open up the disc system and remove the disc inside the player or whichever external body is there. This will not only stop the noise but also get the unit working fine again.
Hope this solution has been helpful?
Posted on Oct 13, 2010
Had ticking sound started up this am loud pop then rough running like there was no muffler
Ford Windstar Starting/Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... I tried to startmy van on a 15 degree morning - heard a loud bang and now it won't start. Battery ....The engine will crank, start run about 5 seconds then stop. ... I have a 2003 Ford Windstar, same problem,Ford is covering up the problem.
Why My Car Won't Start? - Reasons and Solutions
www.myautorepairadvice.com/car-wont-start.html
As a rough guideline, problems with the battery, alternator and starter are the most ...Before I even put the key into the ignition I hear a clicking noise on the right side ...started it and then it started making a loud clicking noise while I was driving it ..... i have a 2003 windstar ford it was clicking and wouldn't start had to get a ...
Rough Idle Engine Dies Loud Ticking!?! Please Help! - Ford Focus ...
www.focusfanatics.com/.../103146-rough-idle-engine-dies-loud-ticking-...
Nov 6, 2006 - Rough Idle Engine Dies Loud Ticking! ... down then dies and then i restart and it has no problems but the ticking continues PLEASE HELP ME ... Level Up0% Completed ... 2. my injectors are bad and the ticking sound is one of the injectors.... Another method is to turn the AM radio on to a place where there ...Missing: windstar
Jan 08, 2016 | 2003 Ford Windstar
I have an Infiniti G 35 2003 and I cannot adjust the temperature settings or airflow nor does the audio equipment work
Common issue with the 2003 Model G35. The culprit is the radio/HVAC circuit board. Unfortunately, since the OEM radio and HVAC system is integrated, it means replacing the entire circuit board which can be pricey. Google "Infiniti ITB03-007" for more information.
Oct 09, 2015 | Infiniti Cars & Trucks
G35 making humming noise from under hood
could be power steering pump,altenator or belt tensioners or idler pullys.
Nov 06, 2013 | 2004 Infiniti G35 Sport Coupe
Own 2003 Infiniti G 35. No switch on inside car
well i have a g35 coupe, i dont know wich one you have if the sedan or coupe. The coupe doesnt have a switch, you just press it on corner of the gas cap and will open...
Feb 15, 2010 | 2004 Infiniti G35 Sport Coupe
2003 Q45 Electrical Problem: Radio/Navigation screen goes blank
YOU HAVE A MODULE PROBLEM THAT IS SHORTING OUT AND TRIGGERING ACCESSORIES CIRCUIT HAVE IT CHECK ''CAN SHORT CIRCUIT AND CAUSE FIRE''
Sep 15, 2009 | 2004 Infiniti Q45
I have a 2004 infiniti g35 and the speakers don't work... howevr the cd and radio console works just fine i just don't hear any sound at all? does any one have the same problem?
03 and 04 G35's had a Technical Service Bulletin regarding the audio system circuit board. I would suggest calling your nearest dealer with your VIN number in hand and ask if the Circuit board has been replaced. If it has it could still be the issue. The radio unit itself could be bad too. I worked for an Infiniti dealer for 10 years and we replaced a lot of circuit boards, and quite a few radio units. On those vehicles, however the radio is not like the radio on most cars. The display is one part, connected to the console, behind that is the circuit board and behind the board is the radio, which is nothing more than a square silver box. More than likely this is going to be a dealer only repair as is the case with most of the newer Infiniti models.
Apr 27, 2009 | 2004 Infiniti G35 Sport Coupe
Replace the tail light bulbs in 2004 infiniti g 35 coup
tail light bulbs are replaced by removing the tail light housings. The housings are accessed by removing the nuts, the nuts are secured behind the inner trunk liner inside the trunk. Remove fasteners holding liner in place, remove 3 nuts for each housing(i believe it's 3 nuts if my memory serves me right), remove housing and replace bulbs
Jan 13, 2009 | 2004 Infiniti G35 Sport Coupe
I removed my cd player to remove a jammed cd on my 2003 G35 coupe
There are several small "ribbon" connectors that can come loose very easily. They look like a flat ribbon like piece of plastic with a hard plastic piece on the end. They come out really easy. just look around
Aug 26, 2008 | 2004 Infiniti G35 Sport Coupe
2003 G35
It is not very easy! I worked for Infiniti for 5 years. If you dont have any experience dont attempt it. Why would you need to anyway?
Jul 06, 2008 | 2004 Infiniti G35 Sport Coupe
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
