Question about Video Game Consoles & Games
Dear fixya i bought faulty playstation 3 from ebay and try fix it.i fixed a few faulty playstations before,but now i came accros problem i can't fix.when i switch power button the green light comes up and playstation seems to work fine,but there is no picture.i thought it was hard drive,and when i wanted to go to safe mode,i couldn't get there either.is there problem with connection to tv or something?can anyone help please.thanks
  • Marek Andrascik Oct 13, 2010
    is it a same problem where you have to reflow and heat up gpu unit?
    Genius:
  • 1,035 Answers
Hi. You may try using other TV or use another HDMI cable. If it is doing the same thing then this might be a motherboard problem. I have this issue before with my PS3 only to find out that the problem is the video chips.
all the best!
Posted on Oct 13, 2010
  • Angelito Rabago
    Angelito Rabago Oct 13, 2010
    you are exactly correct. This will requires expertise specially in using re-soldering equipment. i have mine fixed by a PS3 technician.
    President:
  • 2,653 Answers
More than likely it's a GPU issue.
BUT before we try fixing that I would suggest booting the PS3 with the hard drive out.
If you get the same results, then for sure it's a GPU issue.
Here's a link to a couple of guides that address the issue and how to fix it.
Hope this info helps!
  • RescueTechLA
    RescueTechLA Oct 13, 2010
    Yes, it's essentially the same problem. Would you mind leaving me either 0 thumbs or 4 thumbs? Just NOT two, thanks ;)
  • 3,530 Answers
This is a common issue with PS3. Try this:
1. Turn Off in back (wait few seconds for it to re-set)
2. Turn on in back
3. Turn on in front and hold your finger on it 'till it turns off again -
(you get the beep on then the three beeps for reset and it will eventually beep again and turn off)
4. Turn off in back (wait few seconds for it to re-set)
5. Turn on in back
6. Turn on in front hold finger for three beeps
Make sure first that there are no loose connections and you are using the right cables.
When i try to switch the playstation on , it loads for bout a second then swithces off then flashes red ???? what do i do
There are few steps that you can try In order to fix the error on your PS3. However you need to keep in mind that the steps may not work and you need to bring the machine to sony service center to fix it. You can try 3 things to check if it will fix the problem.
1 - Restart your console.
2 - Take out all cables, and plug them back in.
3 - Take out the hard-drive, and place it back in your PS3 console.
If still have the same problem get intouch with sony and bring it to a service center.
Thanks for using Fixya.
Jan 31, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 has stopped reading disks. could i purchase the part to fix it or is there any place that could fix that problem. when i bought the ps3 i only had the one year warrenty on it from sony,...
This is quite typical of a failure of the laser lens and is very common on the PS3 unfortunately.
The only solution is to replace the laser. If the unit is out of warranty Sony will charge $150 to repair it. However if you are reasonably handy you can buy a replacement laser from around $30 and do it yourself. Ebay is a good source for these replacement lasers. Make sure you order the correct part as there are a few different versions used depending on when your Ps3 was made. You will need to open the unit and check the part no on the laser prior to ordering if you decide to do this.
More information on how to do this repair including exact video footage to demonstrate the procedure is here
I would rate it as a simple to medium level of skill required. No soldering involved.
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
It won't play play station 3 games or blue ray movies
Hi there, it sounds like your blu ray laser has become faulty. Unfortunately this is a very common problem for the PS3 and there is not much that can be done about it. New lasers can be bought but they are difficult to fix. You could buy a new drive from somewhere like ebay at a cost of around £60. They are much easier to fit than the lasers themselves but you must make sure you keep the circuit board on your blu ray drive and swap it to the replacement drive as this is paired to the motherboard and will not work if it is not with the original motherboard.
Hope this helps and thanks for using FixYa
Sep 14, 2010 | Sony Playstation 3 (PS3) Console
My Playstation 3 has stopped recognizing Blu-Ray discs and PS3 games. Will still recognize DVD's when inserted, but nothing else. Is this a problem with the disc reader or a shortage of internal memory?
Hope this helps and thank you for using FixYa
Apr 17, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 will not read blu-ray discs or games.
It sounds like your blu ray laser has become faulty. Unfortunately this is a very common problem for the PS3 and there is not much that can be done about it. New lasers can be bought but they are difficult to fix. You could buy a new drive from somewhere like ebay at a cost of around £60. They are much easier to fit than the lasers themselves but you must make sure you keep the circuit board on your blu ray drive and swap it to the replacement drive as this is paired to the motherboard and will not work if it is not with the original motherboard.
Hope this helps
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 will not turn on turn on switch in back and red lig
is this unit giving you a red yellow light and then it keeps blinking red if so this means is dead but fortunately I have the system to fix this problem what we have to do is heat the solder under the video chip to fix the broken connection and this needs to be controlled with computer and software to protect other small components this is why it has to be done with this special equipment I got other ebay sellers they do have the system too I am an ebay power seller but I don't offer this service on ebay my user Id is flacooo1 on ebay contact me if you want this service
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Hi my playstation 3 has stopped playing blu rays,
Hi , it sounds like your blu ray laser has become faulty. Unfortunately this is a very common problem for the PS3 and there is not much that can be done about it. New lasers can be bought but they are difficult to fix. You could buy a new drive from somewhere like ebay at a cost of around £60. They are much easier to fit than the lasers themselves but you must make sure you keep the circuit board on your blu ray drive and swap it to the replacement drive as this is paired to the motherboard and will not work if it is not with the original motherboard.
Hope this helps
Jul 04, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 - Wont play games or Blu- Rays
Hope this helps
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 60gb not reading discs
The unit needs to be cleaned out very good. Any dust build up at all and restrick the air flow and parts will start failing. If cleaning the unit and the laser doesn't work you need a new laser. $50 on eBay for a do it yourself job. But I recommend calling Sony. This is a common problem that they may fix for free. Hope this helps.
Jul 03, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
