Question about RCA HD52W56 52" Rear Projection HDTV
I have a 52" rca model D52W17. I turn it on and about 10-15 minutes later it just cuts off. Sometimes it trys to cut back on and then goes right back off. I smell nothing burning, screen looks fine when on and dont see any loose wires.
    Genius:
  • 1,030 Answers
Without takeing mesurment i would be makeing a guess = there are some capacitors that could be going bad.. intermetant or delayed shutdown ussally means a overheating or failing component or bad solder connections.
Posted on Oct 13, 2010
  • dkosovan Dec 01, 2010
    This is exactly what happened to mine today. Did you solve this??If so how/how much?
52 Inch RCA D52W17 BYX1 projection screen tv cuts off when i TURN ON
The set literally has a 3 strikes and you are out where it will try three times and go to shutdown.
The common issues this set has are bad solder connections under and around the high voltage transformer and also in some cases the High voltage splitter block (located way up front behind lower grill below screen unit and behind a removable inspection plate).
The transformer rarely fails but can--photo of what is general appearance of this type of part is attached.
Oct 26, 2012 | Televison & Video
My rca p52926 picture cuts in and out
If model number is correct (on rear of set in small letters it should be a PTK 195 chassis) you have a high voltage lead somewhere that is arcing.
This set did have issues with the High Voltage transformer failing and also that High Voltage (well over 10,000 volts) gets distributed to each of the 3 picture tubes this model uses.
Sometimes the lead where it connects to one of the tubes begins to arc---it is coated with white silcone to prevent this.
If arcing around the entry point to any of the tubes sooner or later it will take the set down--destroy parts that are currently ok.
Usually we locate this by turning set on with back off and looking and listening when set is turned on---If a frying or pop is heard up above the main boards--one of the entry points (called the 2nd Anode) is arcing.
I have seen them arc hard enough and long enough to actually crack and break the glass wall of the picture tube.
May 16, 2012 | RCA P52926 52" Rear Projection Television
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
, power cuts off ,
the power cable is broke, but not completely thats why come in and out ...
Dec 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA HD61W66 Turns on then cuts off I NEED SOME HELP
Ive had a similar model since 2002 and it had the same problem. Factory power supply to weak for the model. Mine was replaced twice before the upgrade came out. Sorry, I dont think it is a $.50 solution.
May 25, 2008 | RCA HD61W66 61" Projection HDTV
Rca d52w17 hdvt rear projection Problem
If the light cycles on three time the micro is working but there is something shuting it down.a This is not clear cut it would need to be troubleshot. You need to call a tech.
                                   Packman
Oct 29, 2007 | RCA D52W19 52" Rear Projection Television
D52W17 Takes several attempts to turn on
Hello, sorry about taking so long to reply,do you still need help? If so let us know .Thank You for using FixYa and Have a Nice Day.
Oct 21, 2007 | RCA D52W19 52" Rear Projection Television
Power cutting off and then back on
Most likly a poor or cold solder connection. it could also be a problem in the sweep regulation circuit. Im telling you the longer you wait to have it fixed , its going to cost you more in the future as it will make other parts go bad, with all the surging thatsd going on when it turns on and off.
Sep 22, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W56 52" Rear Projection HDTV Logo
164 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
