Question about Kenmore Kitchen Ranges
How do I remove the door to replace the trim ring?
  • 1 more comment
  • dgscon Oct 13, 2010
    kenmore model # 665.69689992
    are you able to help me?
    not the answer I wanted, but thank you for your insights.
  • 8,197 Answers
May I get the manke and model # to help you more
Posted on Oct 13, 2010
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Replacing quarter glass on left side on 2005 pontiac gto
Remove the door opening weather-strip. Refer to Door Opening Weatherstrip Replacement in Doors.
Remove side sill trim plate. Refer to Door Sill Plate Replacement in Interior Trim.
Remove the lower quarter panel trim. Refer to Rear Quarter Trim Panel Replacement in Interior Trim.
Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement in Interior Trim.
Remove the quarter upper trim panel. Refer to Rear Quarter Upper Trim Panel Replacement in Interior Trim.
Remove the center pillar outer applique. Refer to Center Pillar Applique Replacement in Exterior Trim.
Remove the roof drip molding. Refer to Body Side Roof Drip Molding Replacement in Exterior Trim.
Important: It is necessary to use new nuts when reinstalling the quarter window.
Remove the nine quarter window nuts (1), securing the quarter window assembly (2) to the body opening.
Caution: When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
Important: When removing the quarter window from the body opening make sure that the attaching pins are clear of the outer body.
Remove the quarter window (2) from the body opening.
Remove the rear seat cushion. Refer to Rear Seat Cushion Replacement in Seats.
Remove the rear seat back. Refer to Rear Seat Back Replacement in Seats.
Remove the door sill plate. Refer to Door Sill Plate Replacement .
Remove the 3 quarter trim panel retaining screws (1).
Starting at the lower edge of the trim panel and moving alternately clockwise and counterclockwise, pull outward on the trim panel to disengage the eight rear quarter trim panel attaching clips (2).
Remove the quarter trim panel from the vehicle.
Remove the 4 radio speaker grille speed clips (1), securing the speaker grille.
Remove the speaker grille (2).
Remove the rear quarter trim panel insulator (1), from the back of the quarter trim assembly (2).
Remove 7 rear quarter trim panel armrest retaining clips (1).
Remove 7 rear quarter trim panel armrest retaining nuts (2).
Gently pry the quarter trim panel armrest insert assembly (3), away from the rear quarter trim panel and remove.
You mite look for a video on youtube !
Dec 23, 2016 | Pontiac Cars & Trucks
Removing rear door panel 2004 subaru outback
Remove the trim ring around the inside door handle by pulling it up and towards you first, then downwards.
Remove the switch panel. There are two spring clips holding it. Lever up carefully on the top end edge first, then push the panel towards the car floor. Disconnect the electrical connector.
Remove the screws behind the door handle, under the switch panel mount, and on the armrest.
Dislodge the 7 trim clips around the edge of the door trim, starting at the lower edge and working up. Lift the door trim out of the top channel.
If you remove the plastic sheet, take care not to tear it, a spatula is handy for this.
Apr 15, 2012 | Subaru Outback Cars & Trucks
MDL WED9600TAO WHIRLPOOL DUET STEAM - THE TEARDROW TRIM\r\nAROUND THE DOOR AND UP INTO THE CONTROLS IS LOOSE AND HAS THREE SMALL "CLIPS (?)" STICING OUT BUT I CAN'T SEE HOW TO REATTACH THE CLIPS...
This was a very poor design from the factory ..The clips attach to the trim ring at the factory by plastic welding (MELTING) them in place to the stanchion's, in working on many of these sometimes you can super glue them back in place, but you will have to remove the trim ring completely to do it. other times i had to just replace the entire ring as it was to far gone to repair Just a bad design guess they didn't think it would ever have to be taken apart
Nov 15, 2010 | Whirlpool Dryers
Interior door handle right side
first you need to order a new handle and trim ring, 2 separate pieces. beige or grey are your only choices. www.tnaautoparts.com cheapest and only one i found that caries beige. i did both front doors for 25 dollars total including shipping. Remove door panel, 2 screws under round plastic caps that pry out and off, 2 screws at bottom, 2 lg screws in middle handle, 1 plastic retainer in side that prys out, 1 screw under square cap in the center of the trim ring. remove black plastic triangle shaped piece near the mirror, prys off easy. grab door panel and pull out then lift up. leave wires attached and let panel hang loose. remove screw from old door handle. remove linkage from handle and from lock. connect linkages to new handle and lock (look carefully at the old one before you remove the linkages) , install the last screw you removed to hold lock in place while you check to if everything works. when i finished mine neither door would open from the inside. i had to take pliers and slightly bend the linkage at the elbo's to shorten the travel distance. check this before you put everything back together by just putting the door panel back in place down fist then in, window down, close door, reach in and open door, if it doesn't open bend linkage and try again. when you are sure everything is ok install all screws except the one that was under the square plastic cap in the trim ring. to install trim ring look for notch on back side toward front of ring, push ring in notch end fist, back end slightly out, when the front end is in and seated push the back end straight in. install screw and push cap in. this job is not as hard as it sounds and will make sense when have the panel off and can see.
Nov 07, 2010 | 1998 Toyota Camry
How do I replace the headlights in my 1985 Lincoln town car.
To replace the headlights, you must first remove the trim ring around the headlight. There should be three or four screws holding it in place. Once the trim ring is removed, there will be four screws, two at the top and two on the bottom. Carefully remove screws and remove the retaining ring. Gently pull bulb out, unplug the wire connector. With new bulb in hand, carefully connect the wiring to back of bulb and carefully set in place. While holding the bulb in place, set retaining ring back in place over bulb and insert screws. Then replace the trim ring, tighten the screws and you are done.
Jun 12, 2010 | 1985 Lincoln Town Car
Remove right rear door panel
  1. Remove the rear door power window/power door lock switch
  2. Remove the door handle bezel. Remove the door trim panel screw located behind the door handle bezel.
  3. Remove the door trim panel screws located by the armrest handle.
  4. Remove the door trim panel using J 38778.
  5. Disconnect the electrical connectors.
  6. Remove the door trim panel from the door.
INSTALLATION PROCEDURE
IMPORTANT: Discard the old door trim panel retainers and replace with new retainers before installing the trim panel
  1. Install new trim panel retainers to the rear door trim panel.
  2. Connect the electrical connectors.
  3. Align the door trim panel retainers to the door.
  4. Press the door trim panel at the retainer locations until the retainers are fully seated.
  5. Install the trim panel screws. Tighten Tighten the door trim panel screws to 2 N.m(18 lb in) .
  6. Install the power window/power door lock switch
Nov 04, 2008 | 1998 Oldsmobile Intrigue
Replace side door handle assembly
Remove the snap ring from under the inside door handle and plate (a rag around the base of the handle and a left-right tug on the rag may loosen it, or look under it & pry the snap ring off with a small hook tool
Remove the door lock knob bezel; remove the screw & slide it rearward
Remove the door trim; Remove the two clips; slide a thin, flat wide tool under the panel and pry towards you, there are 8 clips to dislodge
Pull the door trim straight up once all of the clips are loosened.
Easy.
Sep 23, 2008 | 1992 Toyota Previa
Microwave door handle replacement
Solution for GE Spacemaker Ovens (my model is JVM1650BH05)
1- Remove door by lifting it out of hinges. You will need to remove grille first (2 set screws).
2- Carefully pry off the plastic inside door trim. Use a fine knife or putty knife. There are 10 tabs holding the trim from behind. It's OK if you break a tab! Try to pull out as straight as possible.
3- Once the trim is off, remove the 2 visible screws that hold the door handle. NOTE: There are 2 invisible screws so you are not done yet!
4- You now need to remove the metal ring that holds the latches. To do that, grab the metal ring and using your other hand, release each plastic tab one by one (same tabs as above).
5- Once the metal ring is loose, you will see 2 screws. Remove them if they are still there.
6- Position your new handle and attach using the first 2 screws.
7- Reposition the metal ring by re-snapping it in place. Install the other 2 screws.
8- Replace the plastic trim by snapping it back in place
9- Reinstall door and grille. Tell wife or hubby that you are a genius!
Bonus: use metal washers when screwing down the 2 first screws.
Mar 10, 2008 | Microwave Ovens
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
