Question about ASUS P5LD2 Motherboard
Power button Hi i just put my comp into a new case and now the power button on the new case will not power on the comp. when i plug in it the power led flashes thx for all the help u can give Kevin
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Are you sure that is the correct case mite be power button is shot
try turning it on with the cover off... or mite be something isn't connected correctly... lala linda
Posted on Jun 03, 2008
My iphone had 72% charge. i made a call n locked the keypad by pressing the wake up button. noe its not turning on. nor its responsing to charge or anything. wat to do?
first hold power button and circle button together for at least 10secs or until apple logo appears. If that doesnt work plug your phone in to charge and then try the two buttons if you get a battery logo flashing then let go of the buttons and leave your phone on charge for at least 30mins, if that doesnt work load up your comp with updated itunes on and hold down the circle button on the phone while plugging into the comp you should get a message on the comp saying the phone is in recovery mode, release the button then you will need to restore your phone from then either from a backup or as new :D
Hope this helps! Please leave feedback
P.s if you need anymore help just message back :D
Feb 06, 2011 | Apple iPhone Smartphone
Hi, i have brand new Dell - Inspirion 1545, i have install Win7 enterprise, get drivers and comp. is working ok. but when i shut down and not use laptop for hour or two, next time when i press power...
Shutting your laptop off like that can do damage to the hard drive over time, so if you need to take it back to the store you bought it from later on, you may want to leave that part out. (They'll always find ways to make it your fault your computer isn't working so don't make it easy for them)
This could be an easy fix, though. Disconnect the power source and remove the battery, and then press the power button for 30 seconds. This is a default reset on many newer laptops. After that, put the battery back in, plug the power to the wall and you should be set.
One thing I should also mention:
Several Dell models (and a few Toshiba, for that matter), have been giving these same symptoms that require a lot more than pressing a power button, so be sure you know where your warranty information is. If anyone aside from a certified professional opens it up, the warranty is voided, which the salesmen and techhies where you bought it will be more than happy to tell you
Aug 04, 2010 | Computers & Internet
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
My iphone 3gs has hung at the apple logo. reset, draining battery, connecting to i tunes etc does not help. it just doesnt go beyond the apple logo
Make sure you have the latest version of itunes on your comp & power up comp & itunes
-power off your phone
-hold down the home button (around 6secs) then insert USB cable while still holding button then release button when cable plugged in
-itunes will then bring up message saying that the phone has been detected in recovery mode
- it will then give you choice to restore your iphone
-continue with this choice & restore your phone, you can either restore as a new phone (like new) or from a back up (all your stuff back), try from your back up first, if this doesnt work and you go back to square one then do this process again only this time restore your iphone as new and resync your info later on.
Hope this helps!!
Oct 05, 2009 | Apple Red Leather Wallet Case For At&t ...
DOES NOT START SHOWS BLACK SCREEN
do a power drain
- shut down the comp, unplug the adaptor and unplug the battery
press and hold the power button without any power connected to the comp
- plug the battery and plug the ac adaptor and turn on the comp
Oct 04, 2009 | HP Compaq nc6220 Notebook
1tb simpledrive will beep, click, but not work. No joy.
power source jack/plug might be the problem if it has been bumped about or if it was powered up and running before plugging in to the comp.....
i had the problem of my 1tb ext/hdd no longer being recognized because when i plugged it into my comp, the jack was live and not switched of at the wall. the only way i got it to work was to pull it out of the casing and switched it with the 320 ext/hdd i have as they are they same brand..just diff sizes. going to put the 320 into comp to become master drive as the internal is a measly 40g. i think i had burned out the connector pins on the power jack when it was plugged in live. i hope this is an idea for you to try.
Aug 24, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
Comp not firing up
Something may be shorting out the board. Try taking the motherboard out and turning it on without the case. Just put the motherboard and power supply on a non-static surface. A box works well. Then use a flathead screw driver to temporary "jump" the 2 power switch pins for the front panel connection (as you wont be turning it on while inside the case).
If that doesnt work, then replace power supply. You could also take one out of another working computer just to test.
Jun 18, 2008 | EliteGroup K7VMM Motherboard
Power button doesnt shut down
I would recommend replaceing the powersupply.
Apr 05, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Gerry
Jan 31, 2008 | Dell OptiPlex GX270 PC Desktop
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2672 User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
ASUS P5LD2 Motherboard Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
