My Taylor Thermo Sensor model THR138 isn't working properly. Each unit does display the temperature for that particular unit, however the inside unit doesn't show the outside temperature reading. It only show's a series of dashes where the outside temperature should be displayed. I've changed the batteries in both the outside and inside units, cleared both units, and am stumped. Thanks for any help.
  • julieaimhoff
    julieaimhoff Sep 17, 2012
    I have the same problem...batteries have been changed...any other suggetions?
Check the batteries in the main unit. If they get low it will only show dashes for the remote sensors.
Posted on Nov 24, 2010
The Thermo temp flashes HHH ....and the thermometer keeps beeping...??? What do I do!?
That means the temp is higher than the unit is able to detect. If it has been exposed to very high heat then it is damaged. It may still have a bad sensor.
Jun 19, 2016 | Taylor Digital Cooking Thermometer
Remote not working
Alkaline batteries will not work below freezing in the outside temperature sensor. Buy Lithium batteries for the outside sensor unit alkaline are okay for the inside unit.
Dec 18, 2015 | Taylor Wireless Digital Thermometer with 1...
Aprilia sportcity 200cc
It is difficult for me to translate your broken english. Typically a thermosensor is locater in the cylinder/cylinder head area in a water jacket. Some time they can be located in the radiator itself. There is usually a single wire going to a brass appearing fitting.
Jan 13, 2013 | 2006 Aprilia Sportcity 200
Where is the temp sensor on a Hayward H300 ED2 pool heater
Hayward H series with ED option have electronic ignition with one or two dial thermostats. Along with thermostats, there are other temperature safety switches to shutdown the heater in case of over temperature, both for water temperature and for interior cabinet temperature.
CAUTION: Always turn off power, gas and the water pump whenever repairing your Hayward H series pool heater.
CAUTION: The Hayward H series pool heater is essentially a gas furnace. Only a qualified technician with proper training and tools should make repairs of your heater.
I'm assuming you are seeking the location for the thermostat sensor rather than the temperature switches, and I'm assuming you have dial-style thermostat(s). Incoming water temperature is measured at the inlet of the water heat exchanger. For most H series models, provision is made for two thermowells. If your unit has dual thermostats, both of these wells will have a bulb-style sensor inserted directly into the thermowells. If only one thermostat, then one of the thermowell ports will be sealed with a plug. The factory orientation of the water inlet and outlet is on the right side of the heater (as you face the front), but the installer has the option to locate the inlet/outlet on the left side with a field modification. Check your particular inlet/outlet orientation for either right or left side.
The heat exchanger thermowells and the thermostat sensors are located directly behind a two metal access plates that surrounds the heat exchanger inlet and outlet ports. Several Phillips-style screws secure the access plates to the heater cabinet. After several years of outside operation, these screws will likely be corroded and need some anti-rust oil to aid in their removal. When you have completed your examination of the thermowells and thermostat bulbs, I recommend applying some grease to the screws before re-assembly.
Once the access plates have been removed, the thermo-wells can be seen on the left side of the heat exchanger, which is the inlet side. Use the arrows on the top of the heat exchanger as a guide for inlet an outlet. The thermostat sensor bulb is directly inserted into the thermowell without any securing mechanism other than a copper or brass friction strip. I have seen some situations where a small amount of fiberglass has been inserted behind the bulb. The bulb should be inserted all the way into the thermowell until it touches the back. The copper or brass strip is used to keep the bulb in contact with the sides of the thermowell.
(For non-dial thermostat systems, the inlet water temperature measurement is made in the same location, but with a different device.)
CAUTION: The thermostat sensor is a liquid-filled thermo-expansion sensor. It relies on the thermo-expansion properties of a non-compressible fluid to operate the thermostat switch. Take care to not crush or kink the capillary tube between the sensor bulb and the dial thermostat switch.
If you remove the sensor bulb, take care to capture the copper/brass strip in order to use during re-insertion.
NOTE: Thermowells are sized to the particular thermostat sensor bulb. If you replace the thermostat sensor be sure to use the same size sensor bulb as the one being removed. If this is not possible, the thermowell may also need to be replaced.
Check your manual for verification of part numbers. The H series dial thermostat part number is CHXTSW1931. The matching thermowell is CHXTBW1930.
Sep 18, 2012 | Hayward H-series Electronic Gas Pool...
I have a 5744 a little over 1 year old. When you step on the scale the only thing that shows is "00" . It was working fine until today. Tried changing batteries and got the same results.
If display shows 00 - it is Initialization error. To clearthis error, step off the scale. Press on the platform. The display will show"----, then "0000", and turn off. Finally repeat the measurement. Hope this will help you. Good Luck.
Sep 14, 2011 | Taylor Health & Beauty
Can someone tell me where the viscosity adustment switch is on a taylor slush freezer model 355?
you have to brixe the unit first but need a special tool and you can set the viscosity on the display but you have to have the unit running properly and not use sugar free or diet products
Jun 29, 2011 | Taylor 632-33 Ice Cream Maker
Outside temperature not showing on ll bean model # 9021u-it
Try removing the batteries from both the outdoor sensor and the indoor unit. I had the same problem and fixed it by doing this.
Sep 28, 2010 | Taylor 1528 Wireless Digital Indoor...
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 11, 2010 | Honeywell TE852W Weather Forecaster With...
Where is the temperature sending unit on a 1999 VW Passat located.
VW Passat & Audi A4 1990-2000
Motronic System
The Engine Coolant Temperature (ECT) sensor is mounted in the water outlet on the back side of the head. If you vehicle still has a original VW part it will be black in color with a four terminal connector. This device signals the engine management system with the current coolant temperature, the ECU takes this information and uses it to control other such circuits as the idle speed, knock control system, oxygen sensor circuit, exhaust gas recalculation, and fuel tank venting. It is also important to note that if at any time ECU does not receive a signal from the ECT it will substitute a value of 176°F (80°C).
VR6
The Engine Coolant Temperature sensor is mounted in the thermostat housing. The body of the sensor will be blue and the sensor will be blue and have two terminals if it is an original factory VW part.
The engine coolant temperature gauge uses a heat sensitive sending unit to transmit an electrical signal to the gauge. The sending unit is a heat sensitive variable resistor that is located on or near to the cylinder head and threads into an engine coolant passage. The sensors are a Negative Temperature Coefficient (NTC) type. As the temperature increases, the electrical resistance of the sensor decreases. As the coolant temperature changes, so does the resistance of the sensor. The gauge is calibrated within the operating range of the sensor and interprets the resistance value to display the coolant temperature.On models produced prior to 1994, the engine coolant gauge temperature sensor is a single wire terminal sensor.
Beginning with model year 1994, the engine coolant gauge and the Engine Control Module (ECM) temperature sensors were combined into one sensor with 4 terminals. The basic operation remains the same in that their resistance decreases as the coolant temperature increases, however the actual resistance values of the 2 sensor circuits are different. The electrical connector of the 4-wire terminal sensor (1 and 2) is keyed to prevent improper connection of the sensor's electrical circuit.
WARNING When trouble shooting electrical components, always consult a wiring diagram for the particular year, make and model to ensure proper test equipment connection and diagnosis. Failure to use suitable test equipment and testing methods could permanently damage the electrical component(s).
Fig. Beginning with model year 1994, the Engine Coolant Temperature Sensors combined the sensors for the ECM and the gauge into one sensor-1997 2.8L V6 sensor shown
Fig. The electrical connector for the combined temperature sensors is keyed to avoid improperly connecting the sensor's wiring-1997 2.8L V6 connector shown
I hope help you with this, good luck (remember rated this help).
Oct 13, 2009 | 1999 Volkswagen Passat
Electonic Temperature Control
the problem is the placement of the thermo sensors. They are in the wrong location. If I can be honest I would exchange the fridge as i heard more of these horor stories.
Good luck
Apr 29, 2008 | Refrigerators
Computers & Internet Logo
664 people viewed this question
David Payne
David Payne
