Question about GE Zoneline AZ55H07D Air Conditioner
The ptac isnt cooling. the air coming from it is 77 degrees. only the fan is running not the compressor
  • 18 Answers
SOURCE: ge ptac
Hello Tom ,   I'm sure i can help you with this.... I work on these units everyday. unfortuneately im not there to put my hands on it but i will explain as clearly as possible.    The most common problem I tend to find with these units is that the control board  and indoor fan motor tends to go bad in these quite often.  If you put the unit in A/C MODE  and/or Fan mode and set it to high if it will not speed up from low , then your problem could be in a couple different places.   1st.  The bearings in the fan motor could be wearing down ,  2nd  The Control board could be bad  in that its not telling the fan motor to speed up.
And when you tell me that the compressor doesnt run in that mode at any given time..... which the electric heat and heat pump itself works together so that when the load is really tough  that the heat pump doesnt over work and in general saves life on your compressor.
Solution is this.
Take your indoor fan motor off and and drill out the rivits  and it pulls apart easy, and replace the bearings and grease them.
ALIGNMENT OF THE FAN IS A MUST.   doesnt cost much at all the fix this. Just a little time and bearings
Replace the Board in the control box
This my friend will definetly solve your problem.    These problems i see everyday with these same units.
Posted on Oct 14, 2007
  • 31 Answers
SOURCE: Amana PTAC
the reset is the size of a pencil tip and is located below the control board on the sheet metal you will see the pin hole,you have to remove the cover to see it
Posted on Nov 17, 2008
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
SOURCE: Air conditioner constantly running, not cooling house
Ours was worse than yours. It was not frozen up, but it did need freon. The tech told us that the compressor coil (the unit in the attic) was leaking freon and that the unit would have to be replaced within a year, but adding freon dropped the temperature inside from the mid-80s to the mid-70s (on 100 degree days). It might go lower, but we don't set the thermostats below 76. We paid $80 for the service call plus another $197 for 3 lbs of freon (for our 4-ton unit). Total cost: $274. The quote to replace the system with a new 14 SEER unit is $7,000 -- but this will get us through the summer. Oh, be sure to replace your filters monthly and keep your condensor fins clean. Spray them down with a hose (even while the unit is running), make sure there are no leaves or other trash blocking them, and make sure you have 2 feet of clearance around the condensor. Putting plants or other objects right up against it will impede its operation. Good luck!
Posted on Jul 04, 2009
Amana PTAC PTH093E Fan runs at single speed only regardless of setting-auto/low/high Hot or cool air is coming out so compressor/heat coil is working. Reset unit and replaced fan motor-no change.
I've replaced many Amanda control boards. They have micro relays attached to the board. These relays are about a half inch by 1 inch in size, and control line voltage to the compressor and blower motor, and give up quite often. Its probably the board if its a digital controlled board. If it has manual, turn to select, type knob, it will be in that fan section knob. Hope this helps!
Mar 13, 2017 | Amana Heating & Cooling
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
Blower fan running but compressor not coming in.What could be the problem
To get proper cold air set temp 23 degree and mode"cool". If still no cooling, check power in out door unit. If power on, check compressor is working. If not working call repairman to find out exact problem, as there are many reasons for compressor not operating. Thanks.
Jan 01, 2011 | LG LS-K1830HL Heat Cool Mini Split Air...
Stuck at 77 degrees!
Hi
Do not assume the problem is related to the compressor or the sealed, hermetic system; these types of problems happen only rarely. Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the unit should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the unit are both set to cool.
3) Listen for the compressor fan, where the compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the unit will offer very little cooling or none at all.
hope you will be helpfull..
Thanks for contacting fixya.com
Sep 10, 2009 | Cuisinart CWC-1200 Wine Cooler
AMANA PTH153B35AE PTAC Temp drop??
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Jul 04, 2009 | GE Zoneline AZ55H07D Air Conditioner
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
Apr 26, 2009 | Heating & Cooling
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Jan 11, 2009 | Heating & Cooling
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
GE Zoneline AZ55H07D Air Conditioner Logo
64 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
