Question about Ranger Communications RCI-6900F-25 CB Radio
Connected freq. counter to tp 5 and receive went out completly.
    Guru:
  • 773 Answers
You should always connect it with the radio off. radio may need a tech now.
Posted on Oct 13, 2010
Can i I get a receiver for keyboard
I believe the logitech receiver p/n 810-000755 is the dual freq you need for keyboard and mouse, and I have one in hand that I have no idea where the keyboard or mouse went. How does $5 +shipping sound?
Sep 19, 2015 | Logitech EX110 SP CORDLESS Keyboard/Mouse
I have accusound floor speakers and a Yamaha receiver how do I connect, because I only had the bottom half of the speakers working?
The receiver has separate output for subwoofer , centre and satellite which are for Low Freq , Mid Freq and High Freq respectively - you cannot connect all range speakers or Stereo speakers
Jun 13, 2015 | Yamaha Audio Players & Recorders
Galaxy 959 Testing TP3 for AM, LSB, USB with FC-347 or what other freq. counter can be used for this?
An external freq counter will always do a better test then the one on the unit . Do you have an oscilloscope? A function generator will also have a freq counter . Now the ultimate is a spectrum analyzer. you don't need all these but the function generator will work fine.
Jun 23, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Dx-959 freq counter an channel selector don"t
Hello, please tell me what you were doing before and at the time of change. Were the digit lights recently switched? Please give me a little more information so I can be more specific in my answer. Thank you.
Mar 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
The freq counter stays lit at 10.625mnz the claifier knob or the channel selecter will not change the freq counter
This problem, really need to be on a bench to test.. FREE at any good cb shop, to tell you what is wrong.... But most times when a freq counter is not working. Either the crystal is bad, poorly soldered, or its not receiving an input signal. Best way to test is to have a second freq counter external inline using coax.. and check the output of the radio and see if it shows correct or wrong. If it is showing correct they you internal freq counter is messed up. and needs to be check for a bad crystal or solder joints. sometimes even the voltage regulators go bad.. If it is showing a wrong freq on external counter then check the radio's crystal and oscillator circuit. this too can be as simple as a cold solder joint. on the solder side check the small surface mount diode near the PLL, next to the PLL shielded covers. It is normally black these come loose often times too. If you need more help feel free to call or text for more help.
Jan 28, 2011 | Galaxy Radios DX-66V Base CB Radio
I have a new RCI 2995DX . that after 1-2 mounths it go's off frek
Have you herd it off freq? Do you have a freq counter? How do you know that the person that told you it sounds off freq don't have their receive off freq?
if its on a freq counter, and shows not off freq, then the radio is not off freq. There is some other problem.. Or no problem because if it is just some one else saying it, maybe they are just too picky.
Things that could cause your audio to change. If its in your mobile, diving around will make your audio sound different to people. Antenna or feed line problems. If there is a problem with your antenna or feed line, it could make your audio sound bad or off to some one else.
Also, if this unit has been modded, has the clarifier been unlocked? if so that will change your TX freq.
If the unit is new and nothing has been done to it, there should be no reason why it is off freq unless some one has done something to it.
Feb 24, 2010 | Cobra 29 LTD CB Radio
Fta viewsat 2000 setup problem
You will need a sonicview or viewsat switch spliter 110 port 1 119 port2 then go into your menu and ajust the settings 110 tp is 12258 and 119 is12239 and make sure you have the freq on the correct setting11250 scan each alone then save.Also set what typelnb you have on there to hope i helped
Dec 17, 2008 | Yamaha HTR-5730 Receiver
Viewsat ultra update doesn't help
You need to reaim your dish to echo 110 .You have it on bell and bell is down.Try reaim then factory set then rescan and make sure you have the right tp and freq settings freq is 12250 and tp is 12258 then autoscan exit when done and let it sit for 15 min on channel 500 cnn and it should work hope i gave you a fixya thanks :)
Oct 04, 2008 | Yamaha HTR-5730 Receiver
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Ranger Communications RCI-6900F-25 CB Radio Logo
29 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
