Question about Kenmore Dryers
Why is there no heat coming from the dyer? - Kenmore Dryers
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Posted on Oct 13, 2010
Testimonial: "thanks so much "heatman101" , i do have the gas dryer. i used the ohm meter and checked all the electrical items and they're good. so it's the igniter"
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
DOESN'T HEAT
Could be bad heat element. Lift top of dyer, or look from back side with access panel removed, or look thru door if glass door while dryer is running on a heat cycle. You should be able to see red glow of heat element coming on. If not then you will need to open up dyer and remove drum. Inspect heat element for break in coil or coils touching each other or metal frame of dryer. You can also use an ohm meter and read the restence of the coil ...should be just a couple of ohms.
If it is a bad coil you should be able to replace fairly easy. If it is not coil than you will need to check themistor or cycle control switch. Hope this helps.
Nov 10, 2012 | General Electric DHDSR46EGWW Dryer
Admiral dyer model ade7000ayw wont make heat
You will need to replace the heating element and the thermostat. They come in a kit and is a simple job to replace them. Here is a link to the kit.
Oct 14, 2012 | Admiral Dryers
Dyer has no heat coming from it only cold air
limit switch or heat selector switch or heating element bad
Feb 06, 2011 | Heating & Cooling
The dyer is working, but the dyer is not blowning any hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Dec 27, 2010 | Kenmore 600 7962 Dryer
Dyer is not heating maytag dryer D8000
heatman101
rtw
Sep 02, 2010 | Maytag Dryer Lint Filter Screen 33002970
Kitckenaid dyer KGYe6778WH1 Dyer won't heat
This is most likely due to the coils on the gas valve, they can become unstable and cause the symptoms you are describing. The coil kit is part number 279834 and runs about $20.00. It is replaceable from the front and not too hard to do.
Side note: the '8' in your model number is actually a 'B'
Apr 22, 2010 | KitchenAid KGYS850LT Gas Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
LGR4634EQ1-DYER WILL NOT HEAT UP
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Nov 15, 2008 | Whirlpool LGR3624JQ Gas Dryer
Dryer quit heating up,timer doesn't work,this happened all at one tim
no dyer run's just does not heat up,timer never move's,which I think need's too for dyer too heat up,i could be wrong,just happened all at one time
Aug 03, 2008 | Dryers
Dryers Logo
304 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
