Question about Dryers
The dryer humms when I go to turn it on but the drum won't move
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 13, 2010
5 Suggested Answers
  • 686 Answers
SOURCE: DRYER WHIRLPOOL LEQ8611LG1 STOPPED WORKING
your drum rollers are probably dry and need to lubricate the shafts. to get to them remove the lint catcher and the 2 screws you see there. Then lay it on it's back and pry the top off at the corners between the top panel and the front panel. The top will snap off, then on the inside of the front panel towards top remove 2 screws that hold the front to the cabinet and make sure you disconnect the door switch wires then remove the front completly and from there you can spay wd-40 0r use a lite oil on the shafts of the drum rollers. See if that helps. Also check your felt seals. If this doesn't fix ya you might have too weak of a motor. Good luck
Posted on Apr 05, 2009
  • 277 Answers
SOURCE: DRUM DOES NOT TURN
Try turning the drum by hand. If it spins easily with no resistance, the belt has failed. On the back of the appliance you should find a label identifying the Make, Model, and Serial Number. Take down all the information provided, and then find a local appliance shop that carries that brand. Order the new belt.
Posted on Sep 17, 2009
localwonder
  • 6784 Answers
SOURCE: Dryer humms but does not turn unless I rotate drum when turned on
HI. This is a damaged sator assembly in the motor casing. the cooper windings are damaged. this motor will need to be replaced asap, if possible.
Posted on Oct 19, 2009
ginko
  • 19396 Answers
SOURCE: LG dryer model DLG5932s. When
Hi.
When the motor makes an humming noise and does not start, that usually means that the motor is stuck.
Check if you can turn the drum by spinning it with your hand. If drum is seized check the drum bearing and rollers.
Check also the state of the belt at the back of the appliance.
If the drum is not seized and the belt is correctly in place, then the motor must be replaced. The motor can tested by reading Amps. If the motor is OK it will not draw more than 10/12 amps. If amperage is more than that, then the motor is defective.
Here all parts and diagrams for your appliance.
Regards.
Ginko.
Posted on Mar 29, 2011
Why does my maytag dryer when turned on get red hot instantly, yet the motor only humms?
quit buying parts ur motor is shot and u should be or soon be smelling a wireish burning smell.
Oct 08, 2014 | Maytag Dryers
My front end load dryer makes a humming noise when started then goes to pause
Have you checked the drying drum to see if it spins freely? Open the door and verify it spins freely. if it does then the motor may just be in a bad spot. usually after spinning the drum a turn or two it will get it running. it humms and clicks because of the motor not turning and trips an thermal overload switch and you have to wait for it to reset. Now if the drum dosent turn then you have a problem with drum rollers or something stuck in the way of the drum.
Dec 06, 2013 | Frigidaire Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Dryer will not start or turn when you push the start button. At first it would just humm when you pressed the start button now it won't do anything. the drum belt is on and you can turn the drum by hand.
heatman101
Mar 18, 2011 | Maytag Dryers
Dryer has power, belt is in place, when start is twisted, humms only. Drum can be moved by hand, but is stiff, not super loose.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 16, 2010 | Frigidaire GLEQ642A Electric Dryer
I have a frigidaire dryer. The motor humms but the drum does not turn. The belt is not off the drum.
a humming (shaking) motor means the coils have lost there magnetic feild (replace the motor) and it will work fine
please remember to rank this post
thanks
Jun 21, 2010 | Dryers
Oct 19, 2009 | Dryers
Model#GLEQ642AS2
If the drum is not turning and the hum is a nice quiet hum, then the belt on the drum has broken. The hum you hear is the motor turning without the belt.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Aug 17, 2009 | Frigidaire GLER341A Electric Dryer
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Amana Dryer
sounds like a bad motor or something stuck in blower fan.. see if you can maually turn the drier drum if so motor is bad if not something is binding up drum or blower fan.
Nov 03, 2007 | Amana DLE330RAW Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
